Home > Maintenance & Mods (L322) > How to remove and fit a front parking sensor?
One of my sensors keeps falling inside the front bumper, so far I have managed to glue it back in place (the bracket must be broken inside) using a small plastic sucker to keep hold of it and pull it forwards while the glue sets.
This is a short term fix I think, so if I end up having to do it properly, it looks like the only way to do this is to completely remove the front bumper, which seems a ridiculously large amount of work.
Is this the only way? Discovery 4 HSE
Post #103931 27th Jan 2012 3:29pm
TBH if you do remove it it gives you a good chance to clean it lots of dirt traps and means you can work on it a lot easier, though the Censored is getting it right when you put it back on as even the local RR bodyshop didnt get mine right 2nd time but did it when i went back and took them a bit Smile
Could you not remove a splash guard and reach in?
Post #103938 27th Jan 2012 3:55pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
I think the parking sensor itself is pushed into the surround from the rear but the parking sensor with surround fits into the bumper from the front so no need to remove bumper but when you push it in there should be ears or tabs to hold it , atached to the parking sensor surround that clip into the bumper maybe your surround is broken ? As i dont think there is anything to break on the bumper its just a hole all from memory but i think im not too far from how it is Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #103942 27th Jan 2012 4:01pm
Speedy,
You are barking up the right tree.
The bracket that is on back face of the bumper holds the circular element of the sensor, so that you can insert a new one from the front of the car. But in RAVE it says that you need to remove the plastic bumper face in order to get at the sensor properly, and its my bracket that's broken.
Let's hope the Araldite sticks and I never need to actually replace that one! Discovery 4 HSE
Post #103953 27th Jan 2012 4:29pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Car valeter knocked mine in and I was able to get a paw in through the fog light hole- handy For the centre two. (no pun defended)
Post #103973 27th Jan 2012 6:39pm
I took out the fog light and the number plate plinth, no access allowed, it seems completely sealed off, which is good I suppose for keeping the crap out of the wiring end but a pain when you need access. It's holding for now anyway. Discovery 4 HSE
Post #104006 27th Jan 2012 10:27pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Did you ever figure this out without the need to remove the bumper cover, I have one thats pushed in too and its tripped the park aid and park assist so neither is working.
Dealer has confirmed the sensor is broken so not just a case of pulling it back into place.
Only £205 to supply and install a new one but these sensors pop up on eBay etc, for £40 or so, would be a shame to waste the extra if not needed.
Post #506498 26th Feb 2019 6:29pm
