![]() | Home > General > best straight swap headlight bulbs? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1535 ![]() ![]() |
The bulbs are d2s bulbs. You can get cheap ones on Ebay, or genuine ones from the likes if hid4u. The genuine ones are a good bit more expensive, but you take your chances depending on budget.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
i've got 6000k bulbs which i brought of ebay for £17 and they do make a great difference in respect of the light being whiter ..
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Just bought a set for the same price to replace mine as one hass gone a bit flickery over bumps etc when they are cold - apparently a sign of them starting to fail.
easy, just dont touch the filament bit... ... - .- -.
Cheers Stan - not had a chance to look under the bonnet in daylight yet to see if you can get to them - I assume they come in and out through the back like halogens? |
yep.. |
Cheers...
Cheers.
i think a 2003 would be D1S bulbs...but they could be halogens so check first.. V8 facelift Range Rover Autobiography 22" wheels.
pretty sure the vogues all come with bi-xenons which are d2s bulbs dave... ... - .- -.
No - these are definitely bi-Xenons. |
The bi-xenon part is a powered flap in the headlight that changes the beam pattern on full beam... Nothing to do with the bulbs...
thanks for the clarification craig.. |
