![]() | Home > General > possible issue |
Hi mate, sounds like the sticking caliper problem. Several of the S/C owners (including myself) have had it, have a look in the recent posts/search. The rear brake calipers seem prone to it. I have had both rear calipers replaced (cost of calipers about 70 Euro each), labor here is cheap.
supermario Member Since: 27 Oct 2011 Location: UK Posts: 55 ![]() ![]() |
Thanks for the quick reply - going to get it looked at tommorrow. Loving your prices though! |
rich_959 Member Since: 13 May 2011 Location: East Yorkshire Posts: 64 ![]() ![]() ![]() |
Supermario - I posted a thread last week. Had my rear drivers side caliper replaced on Friday at an independant specialist. £75 plus vat for the caliper and £50 labour. |
Thanks Rich. I checked it at lunch only did a 1 mile drive and now it seems fine no burning smell - maybe needs a longer drive? Ill check again when I go home thats a 4 mile drive. If it does seem fine should i bother getting fixed or will it happen again possibly in the future? |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 ![]() ![]() ![]() |
Had 'extra heat' and intermittent gentle squealing sound from offside rear a couple of months ago.
Thanks guys. Took it to the dealers they are reccommending pad change although they said they are fine! |
How does pad change stop the caliper sticking? |
Agree with47p2. Can't see why putting new pads on is going to cure a sticking calliper!
Once the caliper starts sticking it will progressively get worse.
Sorry should of said do a caliper change and recommend a pad change. Said teh pads seem fine but they have been heating up bad and could have cracks |
Yes I agree with that |
Its what I call a B class bug.
These dont look like new brake discs do they? Apparently just changed
Difficult to say from the pictures, try running your finger tip over the shiny surface and off the outer edge and feel for a slight lip at the edge |
