![]() | Home > Technical (L322) > Flat battery |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
was the correct type of battery fitted, it should have been a 110amphr 920 cca type.. ... - .- -.
bosch Member Since: 20 Jan 2012 Location: Kent Posts: 18 ![]() ![]() ![]() |
Yes the correct battery was fitted,
check the charging system , this should read 14.5 'ish on idle if not then the alternator might be the problem.....
Yes it is reading 14.5 on idle i will check the bat in a few hours to see if the voltage has dropped Range Rover SDV8 |
I was thinking maybe it is the heater blower resister, how would i check to see if it is this Range Rover SDV8 |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
My car didn't start this morning either - doh!
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
If that's ok I'd stick a charger on it over night,
Okay if not I will try that, but I jet ski and I do it out of the back of the range and I always leave the back open all-day as I. have changed every light in the car to led and never had a problem before. but will give it ago Range Rover SDV8 |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
interesting comment that driving alone doesn't put enough charge back into a FFRR. would you care to clarify / expand? |
Takes around 30 minutes driving to fully charge a battery after starting the engine |
I drove for 3 hours and the bat still died Range Rover SDV8 |
Hi guys
because of your trade JR, i think a very valid opinion... |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
Anyone want to buy a Lidl battery charger? |
