Home > Technical (L322) > Battery charging through tow bar sockets - which pins?
supershuttle
I already hi-jacked one thread a little so I though I would just start this as a separate topic.
My RR is fitted with the standard (for a 2007 anyway) tow bar setup and therefore has two sockets on the car. I was thinking if I wanted to trickle charge the car overnight in this cold weather I could do it using one or other of these sockets and therefore keep the car locked up and no need to get cables, mains or otherwise, into the car.
So my question is in the title; there are two sockets one with a black cover and one with a white one, I understand that some of the pins are suitable to connect a charger in this way but I don't know which.
Any experiences to share or other help or advice would be gratefully received - the C-tek changer is already on order.
Thanks Thumbs Up Geoff
Post #104436 30th Jan 2012 9:07pm
12 S socket, the white one.
Pin 4 +ve
Pin 3 -ve
Not sure a Ctek will work this way, cableson the car are too long.
Post #104437 30th Jan 2012 9:10pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I believe the bottom pin on the white socket is the live one and the centre one is the earth.
Need to confirm with a diagram or tester Thumbs Up
Post #104439 30th Jan 2012 9:14pm
PaulB
Beat me to it.
I have the cigar adapter for my Ctek and use the boot socket.
Post #104440 30th Jan 2012 9:16pm
Surely if you connect the CTEK through the towbar socket it would then have to go through the towbar electronics box
Post #104452 30th Jan 2012 10:13pm
A1GSS
Here you go:
Can't see any reason why it won't work. Electricity travels both ways perfectly well, and it comes out OK... Whistle Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #104453 30th Jan 2012 10:13pm
supershuttle
Guys
You've given me lots to take into account so I've e-mailed tech support at Ctek for a definitive answer.
I don't want to break anything Sad
I would still be interested if anyone has tried this Thumbs Up Geoff
Post #104457 30th Jan 2012 10:28pm
Vogue
sorry to jump in here, but just a quick thought, as the reversing lights are so poor, we could tap into those cables with an auxillary led reverse light.
sorry now back on topic Embarassed
Post #104460 30th Jan 2012 10:36pm
A1GSS
Hi Geoff
Plenty folks on the sister Disco3 forum do this on the D3.
http://www.disco3.co.uk/forum/ Graham
____
Post #104461 30th Jan 2012 10:37pm
supershuttle
Quick look at D3 (thanks Graham) suggests that this should be fine - Happy Days Thumbs Up Geoff
Post #104468 30th Jan 2012 10:52pm
supershuttle wrote:
Guys
I did try it with a Ctek.
In order that the charger could stay in the garage I connected about 3m of
2.5 mm cable to the chargers output cable as an extension and fitted a 12S plug on the end, +ve to pin 4, -ve to pin 3.
Initially the charger worked ok but after an hour it reverted to "error".
Did it twice. I contacted ctek who advised me this arrangement wouldn't work unless all cables were "large". Presumably for volt drop.
Instead of persuing this I resorted to plan B and and made up a mains voltage extension cable from 0.75mm circular lighting cable with a rubber socket on the end. I put the socket and the charger in the car, connect the charger to the front cigarette socket and pass the mains cable out thro the bottom of the door and close the door on the cable.
No problems to date.
I have a voltmeter on the car and doing the above I loose 0.2V thro the circuit from the charger output. I have a suspicion that connecting to the 12S would result in a larger voltage drop.
The pin 4 on the 12S socket is a direct feed to the car battery and doesn't go thro the trailer wiring ecu.
Be interested to know how you get on.
Post #104514 31st Jan 2012 9:54am
supershuttle
I'll give it a try anyway, it's only a couple of quid for a 12S plug - but I'll use fatter cables Very Happy
Unfortunately, the only permanent live socket I have is in the boot, so the distance to the battery is only a metre difference and the cig socket probably has thinner wire.
I'm cool with lifting the bonnet as I've done for years on various cars but this seems an elegant alternative if it works Thumbs Up
Thanks for all the help and advice guys Bow down Geoff
Post #104518 31st Jan 2012 10:06am
have you considered the solar panel on the dash jobby.. ... - .- -.
Post #104521 31st Jan 2012 10:14am
supershuttle
It's the cold dark nights that are causing me a problem so I reckon solar power wont cut it and I needed an excuse to buy a decent charger Very Happy
although I now also have an excuse to buy a solar charger Whistle
I am charging it up now using an old variable PSU but obviously it requires a bit of TLC and a lot of manual intervention to keep the Heath Robinson setup on task - monitoring current and voltage Geoff
Post #104527 31st Jan 2012 10:59am
supershuttle
Bingo - just fired up Very Happy Very Happy Very Happy Geoff
Post #104536 31st Jan 2012 11:22am
