![]() | Home > Technical (L322) > Flat battery |
How , have you not got a Big battery charger
Think the only cigarette lighter that is live all the time is the one in the boot |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
I leave my solar charger plugged in the boot socket, with the solar charger on the rear quarter window.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless Iām not at home, in which case Iām somewhere else. Posts: 6830 ![]() ![]() ![]() |
![]() ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
@polux
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
Find the fault and see what's no going to sleep.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
not sure if this helps, but "acceptable" drain when tests are done on a FFRR is up to 30mA.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
I was told several hours wouldnt fully recharge a flat battery, i may be wrong though? (Having battery problems myself ![]() |
Polux, when my TD6 battery died on me (couple of times this winter ![]() |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
Whe i first had my TD6 it was not long after that i stared gettng problems with the battery and one day after wrok i went out to the car an dit was dead. I called LANDROVER ASSIST and they soon had her started with jumps leads. I took her into the dealer and they all was ok. Then a couple of months later same problem, this time they measured it and said that something was draining it, back to dealer they stated that all was ok. Same again and AA came out they said that there was a 1amp drain, back to dealer no problem.
Les Pes Member Since: 13 May 2011 Location: Sitting down Posts: 34 ![]() ![]() |
Change the Dealer |
bosch Member Since: 20 Jan 2012 Location: Kent Posts: 18 ![]() ![]() ![]() |
So far the battery has been okay, checked the drain and was reading 0.92 Mv which apparently is normal,
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Not to hijack this thread... But.... I have a battery charger that is a conditioner as well. It willl drain the battery down and recharge fully if need be to bring it fully back to life.... but generally will act as a conditioner and just intelligently charge it to keep it topped up.
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
Things that I would consider:
