Home > General > Rear Wiper on FFRR - Rubbish
itguy
2006 Range Rover Vogue Td6 Cairns Blue
Ok - I'm sure they're all like this but just want to check.
Are they all rubbish because of the 'upside down' design?
Does everyone hate the way that water dribbles down the screen on the right hand side of the glass at the end of the wiper sweep?
Surely they should have designed this out of the thing... *sigh* FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #10443 4th Jan 2010 5:12pm
Vogue
what other options are there for it? If you want a wiper hidden out of sight and a split tail gate, the only option is at the top of the screen. The Sport has a wiper at the bottom and doesn't get goo running down it, but then it looks cheap as the wiper is exposed and not hidden away...
Post #10444 4th Jan 2010 5:16pm
Another problem with the Sport version is that the widest part of the arc is at the base of the glass, not where the drivers vision is at the top of the glass! IMO, the Sport way is upside down.
I am finding my wiper a bit useless but probably needs replacing or a new arm with a better spring. Discovery 4 HSE
1993 90 Tdi
Post #10445 4th Jan 2010 5:30pm
My rear wiper is S Censored t ...... even with a new blade seems as if there is not enough pressure against the rear window .....
Post #10448 4th Jan 2010 5:43pm
might be better with a stronger spring so there's more blade pressure against the screen perhaps? Discovery 4 HSE
1993 90 Tdi
Post #10449 4th Jan 2010 5:44pm
Either that or a new FFRR Thumbs Up
Post #10451 4th Jan 2010 5:50pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
You're not Hawaii yet.
Post #10453 4th Jan 2010 6:19pm
Dolphinboy
I get great wiping by the blade but the water spray bit doesn't work. Any ideas why not? the water pump for the front works fine. does the rear run off the same pump or does it have its own? (I have looked at the schematic but can't find a pump for the rear)
Post #10454 4th Jan 2010 6:51pm
Dolphinboy
sorry, meant to add,...... have had the back cover off adn inspected it and there is no leak. Everything seems normal.
Post #10455 4th Jan 2010 6:54pm
If its not leaking, then the jets could be blocked. Try a sewing needle inside them. Note, the rear nozzles do not rotate, they are fixed so don't try and force them.
If this doesn't work then its one of 2 things:
1. The pump in the rear wiper unit is dead
2. The nozzles and wiper arm need replacing (cheaper option, worth doing first)
Removal of both covered here:
http://www.fullfatrr.com/forum/topic884.html Discovery 4 HSE
1993 90 Tdi
Post #10459 4th Jan 2010 8:19pm
ukrangie
I like the way the rear wiper works. I like that it catches the spray and spreads the washing fluid across the screen.
The only time it has failed me was in the snow where the whole system froze.
Post #10465 4th Jan 2010 10:07pm
The doc
2008 Range Rover Vogue TDV8 Java Black
I love my rear wiper Thumbs Up '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #10474 4th Jan 2010 11:09pm
dan_uk_1984
The no return valve has failed in mine, which means I need to press it twice before I get spray, not exactly the end of the world, but it works fine.
Keep it frost free with a good quality screenwash I think is the key. Plain water could allow algae or something in the tank which could then block the super fine jets.
Post #10483 5th Jan 2010 2:57pm
SteveMFr
Site Sponsor
Often, the spring pressure on wipers is not the way it was originally due to corrosion between the arm and the pivot. Get some penetrating oil and a couple of rags, park your rear wiper vertically and work the oil in by lifting the wiper to 90deg and back until it moves completely freely. I'd be willing to bet you'll see and feel a difference. The rear wipers work fine - except for the end of stroke dribble. But better the wiper than me... Whistle
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #10492 5th Jan 2010 7:27pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
mine seem to rotate and they move Rolling with laughter onto no6 Range Rover
Everyone needs a hobby
Post #10497 5th Jan 2010 7:40pm
