Home > In Car Electronics (L322) > When were the Mk4 maps last updated on the DVD ?
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Ah - I'm on the DVD based touch screen (which I thought was a mk4) - I wonder if the map data files are the same ?
Post #104005 27th Jan 2012 10:23pm
my references are to a touch screen like yours V.V. ... - .- -.
Post #104008 27th Jan 2012 10:34pm
Renegade2
So have just checked my Sat Nav and its is DVD and i have the Touchscreen and the there was a DVD RW Dual layer disc in there with 2007 wrote on in felt tip. Any one have the 2009 with the firmware upgrade or know where i can buy one, not worried about satnav on the move
Thanks
Post #104027 28th Jan 2012 12:55am
you have to be very careful about asking about copied sat nav discs on the forum as this contravenes forum rules.. ... - .- -.
Post #104153 28th Jan 2012 7:21pm
Renegade2
Thanks
Scarey
Thanks for that, the copy was in the car, not purchased by me, what i am asking is that if anyone has the 2009 with the firmware upgrade that they may wish to sell if they have purchased the 2011/12 disc or if anyone knows where i can purchase a new one. I have looked on the navteq site and they only have the 2011/12 version which does not upogarde the firmware.
But yes point taken thank you
Post #104188 28th Jan 2012 11:29pm
Renegade2
Well i have searched every where and there are plenty of the latest 2011/2012 dvds but can not find the 2009/2010 anywhere even navteq dont list it any more, i assume that i can not go straight to the 2011 DVD without having done the 2009/10 upgrade first?
Any help appreciated
Regards
Post #104199 29th Jan 2012 1:24am
i've just put the 2011/12 disc in mine and it worked ok..there seems to be subtle colour changes but this was only observed on a short journey ...
i would make an educated guess that putting in a 2011/12 disc in yours would only upgrade the mapping and you would keep the old GUI... ... - .- -.
Post #104378 30th Jan 2012 4:24pm
Olders
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Interesting. Presumably you have done the 2009/10 firmware upgrade Scarey?
Has anybody tried the 2011/12 disc without the 2009/10 firmware upgrade? Happy to have a PM conversation if people feel more comfortable...
Cheers. -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #104489 31st Jan 2012 12:03am
Olders
scarey wrote:
once you stick the 2009/10 disc in then you cant re-enable the nav on the go function, the new firmware takes care of that...
Is this 100% the case? In the back of my mind I have it that I might have read somewhere that a stealer (or somebody with a Faultmate - if that is the right bit of kit) could re-enable it? Perhaps I am not remembering correctly though! -----------------------------------------------
Post #104490 31st Jan 2012 12:07am
i did the 2009/10 firmware upgrade before the 2011/12 map upgrade so mine went through the proper route so to speak, but i'm 99.9% sure you dont need the firmware upgrade to get the benefit of the map upgrade...if theres anyone near me that wants to try it ,they are welcome to pop in for a coffee and have a go..
the bit where i said you cant re-enable it was referring to putting in an older firmware disc to get this feature ...of course the faultmate/autologic can probably switch it back on again.. ... - .- -.
Post #104508 31st Jan 2012 9:14am
Olders
Thanks Stan. Very helpful - as always! Thumbs Up -----------------------------------------------
Post #104517 31st Jan 2012 10:03am
it appears that the 2011/12 map disc also has a firmware upgrade so if you go from a 2005 'ish disc to that you dont loose the nav on the go feature but if you go from 2005 'ish to the 2009/10 map disc ,you do.. ... - .- -.
Post #105820 7th Feb 2012 9:31am
