![]() | Home > General > Would LR diagnostic software be able to locate a drain? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1522 ![]() ![]() |
Unlikely as for the diagnostic to talk to the system, the system needs switched on, thus creating a drain.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
re the final stage resistor, this might help mrblonde..
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
If you want to check for battery drain on individual circuits buy one of these.
thats a clever little gadget... ... - .- -.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
cheers guys
Diagnostic software doesn't actually do diagnostics - bit of a misnomer. All it does is read DTC's (diagnostic trouble codes) logged in the various systems. So, unless the system causing the batt drain is programmed to look for that particular fault the answer to your question is no.
Cheers SteveMF
"little" probs like this can be a real pita - especially when you have no time, in the middle of winter, and the car won't start. |
Nail on the head there Steve!
http://www.maplin.co.uk/automotive-current-tester-217879
go back 7 posts joe |
@mrblonde
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
a) I haven't seen a red flashing alarm light by the rear view mirror (although the light may have changed position with model year)
Scarey Is there a simple way to see if I've had the resistor upgrade done? Anything I can check on the car? also, if the upgrade was done, could the upgradedone of failed, thus creating the same common fault? |
