![]() | Home > Technical (L322) > Fuel gun keep clicking when refuelling * |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Happens to me with my TD6, I have to rotate gun to the 9o'clock position, even then it may click one or twice on a fill up. |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Have you set off the wrong fuel protection.
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Look in your spare wheel well for a yellow plastic thingy which if you insert it into the filler neck, will reset the system.
Same here since I changed from the SC to TDV8 , now all I do is hold the nozzle upside down when filling up problem solved , main reason for it cutting out is due to the air being pushed up and causing the nozzle to shut off when filling the right way ....
I also turn the nozzle upside down |
I must be posher than Mick as I haven't put my own fuel in for moons now |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
I had this until the last time I filled up when I pushed the fuel nozzle hard down into the filler pipe and something appeared to click, the nozzle went fully in and I was then able to run the fuel nozzle flat out.
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 ![]() ![]() |
There is a technical bulletin to cover this fault and ours suffered when we bought it. The bulletin advises about the 9 o'clock position technique but if that fails, as we found, they refit a new neck - all warranty work but quite an involved job! '96 Volkswagen Polo 1.4CL - SOLD
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 ![]() |
Where can i find the technical bulletin? Would it be deemed a manufacturing fault meaning free repair? |
Hi,
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6379 ![]() ![]() ![]() |
I had this on mine and told the Dealer while it was under warranty. using the LTB the fuel neck was replaced, but it still happens.
Same here although I barely insert nozzle but any excess depression of fuel nozzle and it clicks. Must try the 9 o clock position |
Careful googsy, I tried that last night after jumping off the top of the wardrobe and nearly killed myself ![]() ![]() |
Another excellent example of how a 'gizmo' on the FFRR impedes use, like TMPS etc.
