![]() | Home > General > FFRR letting me down |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
To say these cars are supposed to be all weather, all terrain vehicles, I am rapidly losing faith in the FFRR.
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 799 ![]() ![]() ![]() |
Preventative maintenance would be the key here...... |
The heated front screen only clears the passenger side. - This will more than likely be a bad connection to the screen. If you have any chips get a new screen installed.
JMC you beat me to it! |
It's not the seals, the door won't open from inside when pulling on the handle. I can only assume the internal mechanism is frozen. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
The rear washer issue - I can't hear any pump or motor running.
May have just sucked a lump of ice/slush into it? D ![]() |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
Noddy,
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Spray deicer to the tips before you set off |
Ken you get my PM? |
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
Noddy - did you ever solve your freezing door locks problem?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
nick, i had this same problem last year..the solution is to take the door card off and grease all the working lock parts...wd40 sometimes works but its only a short term fix... ... - .- -.
Mutley Member Since: 29 Jun 2011 Location: Reading, Berkshire Posts: 172 ![]() ![]() ![]() |
Hi guys anybody recommend a particular silicone spray as this is an interesting topic as I spend a lot of time in very cold conditions & I dont want the rip the seals off my doors when I try to open them |
