Home > Technical (L322) > TD6 RE NEW TYPE OF CRANKCASE BREATHER
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Good Day.In some previous postages i have written about new type of crankcase breather.Wondering if can be safely used/installed without any kind of modifications on td6 and whether the bmw part nr fr this filter is 11127799367 while for the all set,including the housing,is 11127799224.
Many thanks for your usuful info.
Post #105672 6th Feb 2012 12:39pm
SteveMFr
Site Sponsor
Yes. It can not only be safely used, you are better off for it as the original strainer oil separator is known for killing turbos. The new one is a vortex design.
There was a thread (at least one) a while back on this topic and I posted info and a pic on RR.net just last week.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #105698 6th Feb 2012 3:47pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
So what are the improvements and are L/R going to sell them instead of the original ? onto no6 Range Rover
Everyone needs a hobby
Post #105707 6th Feb 2012 4:59pm
AKIS
STEVMFR tks for your reply.However just to be sure bmw part nr fr all set,including housing,is the 11127799224?since in ebay i saw that said part nr is for diesels 2000cc?
So want to be sure that will buy the right staff.
Once again tks fr yr reply.
Post #105714 6th Feb 2012 6:24pm
Just change the sponge for £9.90
Post #105719 6th Feb 2012 6:53pm
Renegade2
I recently serviced mine and changed the whole valve as it is five years old not difficult and there is some instructions on wiki under http://www.fullfatrr.com/forum/topic7324.html.
Post #105722 6th Feb 2012 7:26pm
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
I have just replaced my filter and valve housing/body because the valve failed and wrecked my turbo Big Cry Big Cry !! I think because i only fitted the filter cartidge last time and i feeel the valve housing was the original .im changing the complete housing again next too Thumbs Up
Post #105723 6th Feb 2012 7:35pm
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I fitted the new vortex one 2 years ago with no problems to date Very Happy
Post #105737 6th Feb 2012 8:03pm
SteveMFr
Site Sponsor
BMW apparently redesigned the oil separator after the split from LR - and LR never got the new bits. So they don't have them.
The new separator is only about GBP20. And yes, there are engines that last forever with the old separator (without proper service!) and there are engines (turbos) that don't last. If BMW took the time to redesign the separator, there will have been an issue. Using the new bit is only sensible. But I wouldn't stop driving because I don't have it...
As for the PN- I don't know. Will have to search. There is a thread or 2 here on this subject. Search is in the top bar... May have been by fisha (Username)?
Here is the new separator (right) and old at left
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #105783 6th Feb 2012 11:10pm
AKIS
Have done a lot of site search but unfo found only part nr 11127799367 which for the filter.Wondering if any one has replaced both filter and housing so to give me relevant part nr of the all set.
Many thanks
Post #106255 9th Feb 2012 11:18am
Renegade2
the one i bought for my TD6 was from Brit Parts and was a new valve and filter as a complete kit with seals.
8510298 FILTER KIT 1 39.18
Post #106281 9th Feb 2012 12:18pm
AKIS
Renegade 2 thanks for your reply but given part number is for the old type filter.What i am trying to find out is the pn of the new vortex type filter and housing as set. For new type filter pn accg to previous msgs is 11127799367 but cannot find pn of housing as i want to change the all set.
Anyway thank you again.
Post #106309 9th Feb 2012 1:19pm
Renegade2
Just had a quick trawl around and seems that the whole unit part numbre is 11127799224,
see here if this is the one? http://www.ebay.co.uk/itm/BREATHER-FILTER-...5647aee2e6
Post #106315 9th Feb 2012 1:41pm
AKIS
Renegate 2 tks.I've read that td6 and td4 hv same breathers.Indeed fr td4 new filter 11127799224 fits.What bother's me is that pn 11127799224 is fr 2.0l engines.
Sorry for my ignorance but i donot know if this can have affect or not the td6 which 3.0l.If not then this part nr shld be the correct one.
Post #106351 9th Feb 2012 4:11pm
mjdronfield
Hi,
The td4 and td6 have the same filters. No difference.
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #106420 9th Feb 2012 6:52pm
