Home > Technical (L322) > Best replacement battery?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Mikeyjd wrote:
I seem to recall that Varta batteries have a 3 year warranty. It's certainly worth a try.
Cheers Mikey, you reckon I could buy another one ,and send my yr old one back for a refund if its knackered? wasnt sure if they have serial numbers or anything?
Post #104868 1st Feb 2012 7:38pm
Renegade2
Guys the answer is in the link as it states
Voltage: 12 Volts
Capacity: 110 Ah
CCA: 920 A
Length: 393 mm
Width: 175 mm
Height: 190 mm
Cust. Rating:
Guarantee: 5 Years
So that a great warranty period
Post #104908 1st Feb 2012 11:30pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I wouldn't buy a new one, I would take the old one back for exchange, rather than get a refund after buying a new battery. Otherwise you may end up with two batteries. Lol. Batteries will have a date of manufacture stamp somewhere, so even if you lost your receipt you should be ok. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #104910 1st Feb 2012 11:35pm
mrblonde
FFRR wont start - flat (dead as a dodo) battery
Been having drain issues for a while on the TD6, battery is completely dead and FFRR wouldnt even start just now when connected up to mrsblonde 3.0 Audi with jump leads, left of for 15 minutes, is this only because the battery is so dead, or could it be something else?? Rolling Eyes
Hoping its just the flatter than flat battery...........
Post #106379 9th Feb 2012 5:13pm
mrblonde
Cheers Mikey
I definately need a new battery, had the FFRR connected up to the wifes Audi 3.0 for 20 mins and still wouldnt start, I'm guessing its flatter than flat and beyond help? Phoned battery2u who I bought from, the guy at liverpool told me to see a local dealer, local dealer said to call Varta direct and arrange a test with them, that sound right?
Post #106395 9th Feb 2012 5:30pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Your entire contract is with the retailer - it's up them to sort it - you have no contract with Varta - the retailer bought the battery off them - you bought it off him.
Tell him to sort it pronto.
Post #106399 9th Feb 2012 5:34pm
mrblonde
Cheers Simes
Thought so but wanted to double check, was from Battery2u in Liverpool. Whos responsibility is it to cover courier costs etc?
Post #106409 9th Feb 2012 6:02pm
mzplcg
I've done the same before now, left something on and really flattened it. Wouldn't start off jump leads even though my leads are top quality (hand made and expensive) ones. Was trying to jump off a Volvo XC90 and it almost stalled when I was cranking the TDV8 Laughing Laughing
If you're going to charge it off the Audi then disconnect the earth cable on the RR and leave it running for at least 30 minutes. Even with a 100 amp alternator you're still only putting 50AH into a 110AH battery - less than half charge.
Post #106419 9th Feb 2012 6:51pm
sleepezy
Just had a LR tech out to my car. Turns out the problem I had is alternator related, not battery Sad see other post about causing havoc in the middle of Cambridge...
He was really condescending of the Varta / Bosch batteries and recommended only fitting genuine LR batteries. No surprise there I can hear you say, possibly understandably, but his criticism was that they could not take a recharge as quickly as genuine batteries can.
Therefore if you're only doing short runs the constant starting will discharge a battery whereas a genuine part can recharge twice as fast.
I am no techie so am not passing judgement on his opinion, bit thought I should let you all know and would be interested to hear others informed views.
He also said he rarely sees dead batteries on pre MY10 FF's - a dead car (dies while being driven) tends to be either a knackered alternator, completely kaput engine or out of fuel.
Post #109501 26th Feb 2012 5:01pm
Vogue
Odd that, I thought Genuine LR Batteries were made by Varta in any event and also rebranded as Bosch?
Post #109511 26th Feb 2012 5:55pm
sleepezy
Can't pass judgement I am afraid as I don't know. Just passing on what he said. Probably fairer to say he was condescending of the battery I had fitted (Bosch s5 020 as discussed on here and the Europarts recommended fit) rather than Bosch/Varta in general.
Post #109514 26th Feb 2012 6:29pm
