![]() | Home > Maintenance & Mods (L322) > Improving Engine Bay Sound Insulation |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16380 ![]() ![]() ![]() |
06 onwards models have a huge amount of sound deadening inside interia panels... Go to a breakers yard?
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1236 ![]() ![]() ![]() |
Nice one Craig, I will head down to one to see what I can find.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Surely there is the factory insulation? You'll be hard pressed to squeeze any more in? Discovery 4 HSE
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
Plenty of room on top of the engine in a TD6, you could put in quite a thick layer of absorbent material full width which could be lifted out for maintenance. |
Yep the TD6 has a lot of space in there, I could almost put in a whole duvet!
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
It might be worth asking Duckworths Dan what the price is for the pukka 06 insulation/ rubber seals - I wondered if it was worth adding any more sound insulation, but the effort of removing the dashboard was too much to make it worthwhile! |
I'll see if Dan has any info. It is more the insulation that quietens the car to outside that interests me, the insulation to the cabin is amazing already. I don't like waking up all my neighbours every time I start the car, so any improvement on the insulation is a bonus. I know it will never be that quiet, but the new diesels seem almost as quiet as the petrol versions. Tom
These are great for sound deadening |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
It seems to me that most of the noise is coming from that whopping great 9 blade fan, not the engine. When I next have a play under the bonnet, I'm going to whip the fan out and take it for a quick run around the block to measure the difference in noise level - I think it would be quite noticable.
The fan should only make a noise when the engine is hot, could be the viscous coupling is kaput |
The sound deadening material I used from the 06 model was all inside the car, behind panels etc etc... Sorry for any confusion...
No - it works fine, and does exactly the same thing as the brand new one on my Classic (That was stuffed until I replaced it.). First thing in the morning, roars for 30 seconds or so as the car takes off, then quietens down a bit. On a hot day (35 degrees +) in traffic, it roars as it starts to lock up - as it should - as it gets hotter, but apart from that, spins around minding its own buisness, but they still do turn, and they still do make a noise - just not as much as when it is hot... |
My interest is in trying to deaden the normal diesel clatter noise. The bonnet has the stock factory fitted padding on the inside but I was wondering if the newer models have a thicker padding here and any other engine bay deadening rubber seals, covers etc that can be retrofitted.
