Home > Technical (L322) > New battery - then no blower ?
Johnte
Fitted a new battery yesterday, went out this morning, started fine Thumbs Up Thumbs Up Then turned on de-mister to clear ice.. and no blower Big Cry Could the new battery kill the FSR ? searching seems to show this is a common fault for the blower not working. Where do I find this 'FSR', and is it a fairly straight forward job to swap?
Thanks..
Post #96998 10th Dec 2011 4:33pm
I can't think why putting a new battery in should kill the FSR other than possibly blowing a fuse for some reason but this shows where it is and how to replace it.
http://bimma.me.uk/2009/03/13/replacing-th...kiii-2002/
Post #96999 10th Dec 2011 4:50pm
Johnte
Thanks for that ^^^ Thumbs Up
According to the book, the front screen works on the same fuse, and that's working OK, so I'm guessing the fuse is OK - but I'll go out now and double check..
Post #97003 10th Dec 2011 5:00pm
if you do have to replace the fsr then this will help.
http://www.rswsolutions.com/index.php?opti...;Itemid=78 ... - .- -.
Post #97008 10th Dec 2011 5:26pm
Johnte
Just went to check the fuses.. someone has gone with the plastic tweezers Big Cry
Post #97013 10th Dec 2011 5:32pm
tbh john long nose pliers do a much better job than those plastic tweezers... ... - .- -.
Post #97014 10th Dec 2011 5:36pm
Johnte
Stan, thanks for the link.. from that site
' Secondly, when the FSR fails, the blower motors have the potential to activate even when the key is in the Off position. When this occurs, no one may be in the car at the time. A long term symptom of this, is that the main vehicle battery may drain very over 3-6 days of sitting in a garage.'
Maybe I needn't have bought a new battery. Big Cry
For the past few weeks, I've heard this noise (blower?) after I've got out of the car.
Do you think I should disconnect the battery when I'm not using it - can any damage be done to anything else (apart from flattening the battery) Until new FSR arrives..? Could it overheat ?
Post #97016 10th Dec 2011 5:44pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Hi mate
How did you get on with your battery drain issue? I bought a Lidl intelligent charger and will trickle charge until my drain issue is located
Post #106694 10th Feb 2012 8:45pm
Johnte wrote:
...someone has gone with the plastic tweezers Big Cry
It will have fallen inside and they are a swine to get back out Big Cry Big Cry
Post #106710 10th Feb 2012 10:06pm
