Home > Technical (L322) > bluetooth
SteveNorman
bluetooth
Hi,
I am having trouble getting a couple of phones to work with the bluetooth on a 2005 model year.
I can match the phones & they show up on the display, no problem, you can dial a call & it will ring, but the moment to other person picks up, it disconnects. The same happens when you answer a call, it will ring as it should, but drops as soon as you answer.
The phones causing the problem, are a Nokia 6300 & a Motorola razor V3.
I tried a slightly older nokia & an older Motorola razor, no problem, everything works.
Any ideas?
Regards
Steve
Post #1068 16th Oct 2008 9:31am
jpr
Sounds like a software issue with the phone module, the stealers will gladly update this for you and £130 of course Thumbs Up
Post #1069 16th Oct 2008 9:37am
SteveNorman
Sorry, I forgot to add, I have updated the vehicle to the latest software, & it made no difference
Regards
Steve
Post #1070 16th Oct 2008 9:55am
could be the Default settings on the phones which will be found in their sub-menus when using Bluetooth : ie "Headset" or "Wired car Kit" or "Wireless car Kit" plus do you have any Active Diverts on any of these Phones. ====================================
Post #1072 16th Oct 2008 11:48am
Riggers
United Kingdom 2005 Range Rover Vogue 4.4 V8 Zermatt Silver
Hello, I'm new to the forum with a question.
Has anyone managed to resolve this disconnection conundrum?
I have exactly the same issue, same car, same phone, same problem!
Any help much appreciated.
Post #7560 1st Oct 2009 9:21pm
try reading this thread, it may help you out.
http://www.fullfatrr.com/forum/topic946.html Discovery 4 HSE
1993 90 Tdi
Post #7561 2nd Oct 2009 11:01am
Riggers
Thank you for your reply.
I had seen that thread but it relates to the 2002-2004 BMW system RR, so it doesn't address the problem that I have.
Mine is a 2005 Vogue with a factory fitted phone system. On connecting my Nokia 6300 (listed as fully compatable on the Land Rover site) via bluetooth I get a connection. However, as soon as someone answers a call, incoming or outgoing, it disconnects.
As an aside, I always have to type in 2121 when the car & phone connect via bluetooth even though it is selected to action the connection automatically.
Any ideas much appreciated!
Post #7563 2nd Oct 2009 1:05pm
I had to do that 2121 code with nearly all bluetooth phones, except on one occassion i had the Nokia N80 which connected and disconnected automatically without using the 2121 code ........
With regard to the 6300 is there a sub menu on that phone that tells you in my earlier post of "headset" "wireless car kit".
It's been that long since i mucked about with phones , hence the reason i just use the cradle phone in the centre armrest and sync diverts from that to my everyday use phone, and vice versa.
Post #7566 2nd Oct 2009 2:55pm
Riggers
There isn't a sub-menu with anything remotely like "Headset" or "wireless car kit" unfortunately.
I may end up having to look for a Nokia cradle & follow your idea of Sync diverts etc.
Post #7572 2nd Oct 2009 8:51pm
I don't even know anyone with a Nokia 6300 to help you out......
Found this on one of the Nokia Forums......
I am having trouble trying to pair a 6300 with my Range Rover . DOES ANYONE KNOW HOW TO DO THIS AS THE CALLS KEEP DROPPING. NOKIA SAY THAT THEY CANNOT GIVE ME THE OLD SOFTWARE ( I NEED THE JAN 07 VERSION) AS MY PHONE IS THE AUGUST 07 VERSION NOKIA SAY THEY CANNOT GO BACK THE WAY WITH UPDATES.............
Post #7573 2nd Oct 2009 8:59pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
have you cycled the phone menus? It seems something like the trusted one or the discoverable on 3 min.
I have a moto V8 and it works fine most of the times. Sometimes it doesn't disconect from the car. Some other times the car screen shows a ''phone not conected'' message, but when I dial a number on the phone it conects itself and works perfect, and the same happens when i'm receiving a call.
I also had a Porsche design 9521 and it also worked fine...
But do try messing up with the phone menus. Your problem seems to come from there.
Post #7575 3rd Oct 2009 11:24am
Riggers
I have been using the Nokia 6300 because it is listed as being fully compliant on the Range Rover site and I happened to have an old phone spare.
I did try to use the phone with the old Nokia software (v5) but that didn't work so I updated to the newest Nokia software and that doesn't work either.
Nothing on the menus or sub-menus that I can find that gives any options to enable or disable Bluetooth or Headset or Wireless or Phone book.
Stumped!
Post #7576 3rd Oct 2009 1:32pm
Ivan
Ireland 2005 Range Rover Vogue SE Supercharged Zermatt Silver
I used a 6300 with the bluetooth in my '05 S/C with no probs. As I mentioned somewhere in another post when I got the car I could not get any phone to work. I unpluged the blue tooth module, let it sit for 10 min. plugged it back in and everything has been fine since!
Ivan FF RR S/C (Gone)
TVR Chimaera 500(Gone)
TR7 V8
Post #7589 4th Oct 2009 7:13pm
Riggers
Thats a trick I haven't tried. I'll give that a go tomorrow & see if it works for me.
Thanks Ivan! Thumbs Up
Post #7590 4th Oct 2009 9:56pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Where is the bluetooth module?
Post #7591 4th Oct 2009 10:07pm
