Home > Technical (L322) > Help
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Help
The interior light in the passenger footwell has gone off
Ive checked the bulb and its fine
Does anyone have any suggestions please?
Post #107096 13th Feb 2012 1:47pm
A) Use a better topic heading, you will get more "Help"
B) Check the wiring (most likely), check the fuse (but other lights will be off as well if the fuse was the problem) .
Post #107199 13th Feb 2012 10:31pm
How do you know the bulb is fine, have you swapped it for one that you know is working? Discovery 4 HSE
Post #107200 13th Feb 2012 10:34pm
