![]() | Home > Technical (L322) > Gremlins! Known issues or do I call Ghostbusters? |
All of this smacks of low battery voltage, a rather well known phenomenon with these cars. Assuming you haven't replaced it in the previous 2 years it would be wise to get it tested. At the same time it's worth inspecting and testing all the various earth straps. I had a loose one which was causing radio interference - go figure.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7981 ![]() ![]() ![]() |
I have the windscreen wind noise sometimes. I fastened down the A pillar trims with new clips, which made it better, but has not totally cured it..
elbitrevnoc Member Since: 17 Mar 2010 Location: Berkshire Posts: 150 ![]() ![]() ![]() |
Thanks both for taking the trouble to respond. I'll get the battery checked out for a start as that sounds a good shout. In fact, now I think about it, I have had a flat battery on two occasions, after leaving an internal light on, so maybe it's not back to full health. I'll definitely try the taped up scuttle experiment as well - I reckon this is along the right lines, as the noise only starts at speed, when the air flow increases.
Made me smile.
Joking aside,
Sounds like battery as normally once discharged on Landrovers they never seem to regain their full power. If your battery is 3 years old or more it would be a good investment . I changed to the Bosch Silver Battery with 110AH and 920 CCA and havent had any issues since like a lot of folks on here.
