![]() | Home > Technical (L322) > Freezing Diesel |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
There's a discussion on the Defender forum about when fuel is waxing etc, some useful info there:
Good read RRUK |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1115 ![]() ![]() |
Mine unlocked and started fine at christmass, but then went in to limp home mode which can only be reset with OBDII.
magicbob Member Since: 03 Jul 2011 Location: Perth Western Australia Posts: 157 ![]() ![]() |
What you really need is a holiday down under...cooled down a bit this week....only 31 c today. Magicbob ![]() |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
wind chill can effect anything.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
It will if the sufaces are wet and latent heat comes into play. |
in sub zero the surfaces will not be wet for long, so the inaminate object will reach ambient temperature soon enough.
Not really.
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
The temperatures on both thermometers will be identical if their surfaces are bone dry. Wind chill is mostly about surface moisture and rate of cooling, so the other posts are correct in that the rate of cooling will be quicker but it being impossible for the actual temperature to go below ambient is incorrect. The temperature of a moist surface in wind (as long as the air humidity is not 100%) will be colder (whether flesh or metal!) due to the absorption of latent heat of vapourisation mostly. This is the principle of the wet bulb depression in whirling psychrometers used to measure air humidity. What the air humidity in the alps is however remains a mystery as I have no idea!!! Just my wee sciency input! T |
