Home > Maintenance & Mods (L322) > Best replacement jack options to replace scissor jack.
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
My scissor jack is on its last legs after using it once to change over my wheels (terrible build quality for such a heavy and expensive car) and I have read many stories of them failing, so I am looking to chuck it and replace it with something that will fit in the spare wheel bay or tuck in to a side pocket. This will make it easier and quicker to put on winter wheels etc.
Does anyone here recommend any particular trolley or bottle jacks that are small enough to keep in the car, but also able to deal with the height required on the L322? Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #107257 14th Feb 2012 10:46am
Paddocks do a good trolley jack for about £35, but obviously not something to keep in the boot.
My scissor jack is also scrap, think I would have to use the AA to change a wheel if I was away from home, and use the trolley jack otherwise. Discovery 4 HSE
1993 90 Tdi
Post #107260 14th Feb 2012 10:51am
some of the options you have are,
get another scissor jack....waste of time
get a bottle jack.....fits in the range but a bit dicky to use
get a 3 ton high reach trolley jack.....does the job but big to carry around
get a can of tyre puncture foam......small and easy to carry but wont repair a split or blowout
get roadside breakdown cover .....easy life but you'll have to wait for them to arrive ... - .- -.
Post #107263 14th Feb 2012 10:54am
Flashman
Looks like the bottle jack maybe an option then, I think the P38s had it as standard, I want something that enables me to change the wheels for winter/summer/offroading as well as for puncture replacement. Last time I used the foam can, the tyre was too gone due to a screw embedding itself in my nearly new tyre. Tom
Current Drive
Previous Drives
Post #107265 14th Feb 2012 10:59am
i've covered my options pretty well i think,
scissor and bottle jack in the range, breakdown cover and a trolley jack at home.... Mr. Green ... - .- -.
Post #107266 14th Feb 2012 11:02am
Flashman
Thanks for the info guys. Tom
Current Drive
Previous Drives
Post #107271 14th Feb 2012 11:09am
jaybear
France
What about the inflatable bag that some use even off road when the ground is too soft ??
You know the ones that you put on your exhaust ??
you have to be careful with the exhaust heat , but stilll ....
Jaybear Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #107275 14th Feb 2012 11:20am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Send the wife to the gym to build up her muscles enough to lift the corner....
Post #107279 14th Feb 2012 11:32am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
I'm with Scarey
Scissor & bottle jacks for road side repairs. Trolley jack at home. And break down cover as well
Gary
Post #107327 14th Feb 2012 4:20pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Any recommendations on trolley jack? Ideally low enough to fit under the Aston as well?
Post #107376 14th Feb 2012 7:15pm
Another option, get a used airbag suspension strut and use an airline fro
A tyre compressor to blow it up Smile should cope with the weight as its designed to Very Happy
Pity the air suspension isn't like the Citroen system as you can put the suspension on high, place jack or object underneath and set suspension I low and watch the wheels pull back into the arches and thus lift said corner clear off the ground Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #107394 14th Feb 2012 8:08pm
machine mart is where i got mine....3 ton about £80 .... ... - .- -.
Post #107410 14th Feb 2012 9:07pm
L322Pilot
England 2002 Range Rover Vogue 4.4 V8 Buckingham Blue
Thefirst time I used the supplied scissor jack it buckled and I could not bring car down, had to drive it off and risk body damage. Bottle jack purchased from Lidol for £18 and it fits in the spare wheel compartment.
Post #107431 14th Feb 2012 10:44pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Make sure trolley jack has enough height, and also a low height when not jacked, to enable getting under suspension with flat tyre.
As most trolley jacks will not reach the chassis of a Range Rover, then lift high enough with hanging suspension arm.
Post #107433 14th Feb 2012 10:53pm
This is good but would need a plug of sorts for the other tailpipe on an ffrr...
http://www1.conrad-uk.com/scripts/wgate/zc...rwidth=320 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #107435 14th Feb 2012 11:00pm
