![]() | Home > General > 2004 4.4 MPG? |
autobiorob Member Since: 18 Nov 2011 Location: Peterborough Posts: 33 ![]() ![]() ![]() |
I've got the 4.4 and around town you are looking about 14-15 but on a run about 20mpg maybe a little more |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
My computer usually averages 17-18mpg per tank. I run on LPG at every opertunaity. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
24-25 around town in my TD6 and 30-32 on a run |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
If you are after a nice clean 4.4 then you should look at Gazellio, he buys the very best cars out there, he has a lovely Autobiography 4.4 right now.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I do mostly medium distance runs in mine - work is 69 miles each way - Along A5 and A14 and I get 21 to 22 MPG on that run each day - but I only have to slow down about twice on the run and the rest of the time is steady 65 - 80mph - depending on traffic and slow morons in outside lane... |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
@Cannondale: PM sent.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
how much quieter is the petrol to the td6? ... - .- -.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Petrol is a lot quieter inside - and sounds like a Range Rover and not a Massey Feguson...
@mr blonde, blank your egr valve , 3/4 mpg increase..... |
Do it Stan - you know it makes sense...
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Do it, Stan. |
I suppose I should have said that all my figures are quoted using the cheapest supermarket petrol I can find. I work on the fact that it all comes out of the same tanks at the refinery - and if it's inflammible then a Range Rover (or any Land Rover) will burn it (copiously) and convert the burning to movement in some inefficient way! |
