![]() | Home > Technical (L322) > High initial RPM |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Mine does this and has done for as long as I can remember. I put it down to the car needing extra charge to replenish the battery. Mite be wrong though. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Same car as the OP here, does the same thing. Never given it a second thought TBH, I've known other makes of car do the same and I just put it down to the engine being stone cold and needing that boost - bit like a choke! |
hongkongphooey Member Since: 27 Aug 2010 Location: Douglas. Posts: 227 ![]() ![]() |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6827 ![]() ![]() ![]() |
My S/C does this every time I start it. It gives a fantasic "whooshing" sounds for about 30 seconds, and scares children and those of a nervous disposition! |
