Home > Technical (L322) > Webasto fuel burning heater remote**
5IMON
Bonjour , HVD!
Now down to business . I bought a webasto land rover remote for the rr t91 brand from flebay and I spoke to my rr dealer and they said that the webasto remote and receiver is an aftermarket mod and that the standard rr with fbr receivers are rr receivers and not webasto. Consequently, I would need to buy a rr remote and have that tuned in ?
What doe people think of this ?
Sounds like bs to me .
lots of love
Xxx ps apologies for the poor grammar I did this on my phone
Post #107398 14th Feb 2012 8:24pm
SAppie
Hi 5imon,
As you say, it's complete and utter BS. I have both the T90 and T91 remote working perfectly. The only thing that you don't mention though is what year yours is, as you will need to have at least the T90 radio/receiver fitted which I think was only installed from 2006 onwards (not sure of this)...
If you have the correct year, then just search FBH and you will come across all the help you require. Very Happy Thumbs Up MY2007 Vogue SE TDV8 - Tonga Green / Sand
MY2005 Discovery 3 - Silver / Biege
Post #107402 14th Feb 2012 8:41pm
simon1233
I was looking at T91 remotes the other day on the bay and was astonished at the difference in prices depending on whose logo is on the remote. Seems that a VW logo'd remote is 1/4 - 1/3 of the price of a Landrover one. If these will work I'm thinking of getting one, but not a Landrover one Thumbs Up
Post #107404 14th Feb 2012 8:52pm
SAppie
I'm not sure about the other branded remotes, all i know is that the Webasto and obviously LandRover remotes work as I've got them both. MY2007 Vogue SE TDV8 - Tonga Green / Sand
Post #107407 14th Feb 2012 8:59pm
simon1233
Just bought a genuine landrover one for £25 on eBay Thumbs Up
URL for anyone who is also interested
http://www.ebay.co.uk/itm/Genuine-Range-Ro..._500wt_922
Simon
Post #107412 14th Feb 2012 9:09pm
5IMON
It's a yer 2007 vogue not an se , does that matter?
Post #107418 14th Feb 2012 9:26pm
5IMON
The other thing is, there is no aerial stuk to the window in the boot , does this mean I dont have the receiver? Tdv8
Post #107419 14th Feb 2012 9:28pm
SAppie
no, that makes no difference, however you need to check that it has the receiver fitted in the first place.
Have you got access to the LR Microcat program? I have , if you pm over your VIN number, I can tell you if it was fitted at the factory. MY2007 Vogue SE TDV8 - Tonga Green / Sand
Post #107420 14th Feb 2012 9:29pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Whereabouts is the receiver situated??
T
Post #107422 14th Feb 2012 9:49pm
SAppie
T
HI, It's located in the boot, on the right hand side, open up flap, and then its located behind the fuse box, you will have to undo the fuse box and flip it over to see it.
I'm sure I posted a pic somewhere in the forums... here is a link to one of many bits and pieces I put up regarding all the issues I had in getting the remote to function:
http://www.fullfatrr.com/forum/post71843.html#71843
use the search function, it works well.... Thumbs Up MY2007 Vogue SE TDV8 - Tonga Green / Sand
Post #107424 14th Feb 2012 9:58pm
SAppie
I never found the aerial stuck to the window that others have mentioned. Maybe its a different system in the MY2007 onwards?? I had to actually remove the fuse box to actually see it . Has a big webasto sticker on it. MY2007 Vogue SE TDV8 - Tonga Green / Sand
Post #107425 14th Feb 2012 9:59pm
simon1233
FBH uses the tv ariels in the rear side windows. There isn't a specific ariel Thumbs Up
Post #107427 14th Feb 2012 10:27pm
5IMON
Where is the in number located ? How many characters is it?
Post #107462 15th Feb 2012 2:49am
SAppie
The VIN is located in the front windscreen, at the bottom of the passenger side when looked at the car from outside.
Also should be written in your service book. MY2007 Vogue SE TDV8 - Tonga Green / Sand
Post #107464 15th Feb 2012 9:11am
simon1233
The receiver is located on the back of the rear fusebox at the end closest to the boot. you can see that there is a cable coming down from the TV ariel (yellow connector) and also a power connector.
And this is what the ariel connector looks like above the rear fusebox
I now have the original (comedically oversized) T90 remote and a nice new T91 remote paired up and working on mine. Pulling fuse 59 didn't work for me, but pulling the power connector from the receiver and then replacing and pressing the off button on the new remote within 5 seconds worked a treat Thumbs Up
New remote a much better size
Simon
Post #107800 17th Feb 2012 3:36pm
