Home > General > Piece of Junk Chucked it Again
Page 2 of 4 <1234>
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
Not forgetting the cold start engine squeak has been sorted too.. Laughing
Post #107364 14th Feb 2012 6:37pm
Well i did know they were going to fix the camera for nowt …
The cold engine squeak is just something that occurs on those SC's , previously had it done a couple of years back …
But then again what can you Expect when you pay £16k for a car …. Thumbs Up ====================================
Post #107370 14th Feb 2012 6:48pm
Anyhow anyone know the answer to the earlier question …..
Meant to ask as well if anyone knows …. What with this car having a starter button to fire it up , if the steering wheel is locked on is there some other way that you can unlock this …. ====================================
Post #107371 14th Feb 2012 6:49pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Was there any message about the smart key not being recognised?
I have found that sometimes mine doesn't "see" the key. Easist thing is to lock and unlock via the remote. But you are supposed to hold the key up to the dash to the left of the steering column.
Post #107378 14th Feb 2012 7:18pm
Could it be the battery in the remote being a bit low? Previously..
Post #107384 14th Feb 2012 7:47pm
No message at all , the car opened and closed remotely with the key during the 15 min period as i kept trying it …
Just wouldn't fire up ====================================
Post #107385 14th Feb 2012 7:47pm
johnson1
Does the FFRR use the same start button system as the Jags? There was an issue with faulty start buttons that were sending the wrong signals in new XJs - would randomly switch the cars off and unable to restart!
Post #107390 14th Feb 2012 7:55pm
TBH i don't know if they do …. ====================================
Post #107391 14th Feb 2012 7:56pm
johnson1
It's more than likely. A mate of mine had a faulty start switch and it was booked into the stealers for the next day. The day before was driving alone, engine randomly switched itself off (faulty signal) and wouldn't restart. Had to be recovered. Definitely get it checked!
Post #107392 14th Feb 2012 7:59pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
I believe RRs wont attempt to start unless it knows the battery is capable of doing so, this is to prevent damage. Could the connections to the battery be loose? Next time try twisting the connections on the battery slightly
Post #107393 14th Feb 2012 7:59pm
Nick, also, don't tell Mick that the faulty rear washer has been fixed for the sum total of 30p. Rolling with laughter Discovery 4 HSE
Post #107415 14th Feb 2012 9:16pm
We can always swap Mick Very Happy
If i were you i'd get it booked in asap as when the SSRR i had did that it chewed the engine up after the next few days as it ate a maxi fuse then the bottom end of the engine..
Last i heard it needed a new tallblock and was awaiting delivery of said unit.. it was on a 60plate and had some silly low miles IIRC, and the same engine as your ffrr!!!
At least the 'jag' can still get you about while you need to get the dog sorted at the local beauty centre for poochs....
Wink Very Happy
PS if the latest LR advert is to be believed, the SSRR's are built in the LHC!.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #107414 14th Feb 2012 9:16pm
I got the rear washer renewed before I traded it in , a full new washer arm assembly if he checks the paperwork I think it cost £135 incl labour from the dealers in Stirling .... About 7 months back ...
Looks like you have been bumped for 30p Laughing Laughing ====================================
Post #107416 14th Feb 2012 9:24pm
Your tank of diesel will last forever in the TDV8 Mick Thumbs Up
Cos it won't start Rolling with laughter Rolling with laughter Rolling with laughter
Post #107421 14th Feb 2012 9:48pm
That's true 47 as after one park heat cycle while waiting for recovery it will only use 1/2 a litre, though I bet the guys at the LR dealership will give it a good try when they get it running again Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #107428 14th Feb 2012 10:34pm
Page 2 of 4 <1234>
