![]() | Home > Maintenance & Mods (L322) > Best replacement jack options to replace scissor jack. |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I got an Arcan 3t one from Costco for use at home, it's shallow enough to get under low cars but crucially, has just enough lift to get the wheels up off the ground when using it on a FFRR...
1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 ![]() ![]() |
Ironic this thread has started as I had a puncture on Saturday, scissor jack bent under the weight and I had to use the AA to get me on my way.
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
That Arcan one is just the ticket. Pity there isn't a Costco near me.
That Arcan one above lifts 19-22" according to the ebay ads |
farrellelion Member Since: 05 Jul 2011 Location: Oliveira do Hospital Posts: 22 ![]() ![]() ![]() |
As the RR scissor jack stows easily in the boot, I would like to keep mine in it's place. Would it be possible , worthwhile, to remove and weld thicker sections in place of the weaker struts? Any idea of what thickness the replacement arms should be? Where does the metal usually fold- I presume always in the same place ?
Before the L322 Range Rovers had bottle jacks. Scissor jacks were, I guess, a cost cutting exercise Regards
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
. . . . whilst on the subject of jacking - |
Not sure but I think what I'd do is raise the car on the air suspension, insert jack to touch the jacking point, lower car to access height. Would this cause a problem? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35686 ![]() ![]() |
info in rave and in the forum , use the search function... ... - .- -.
