![]() | Home > In Car Electronics (L322) > Failure.... |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
hmm CD/mp3 not available anymore on my car |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
Time to a 4.4TDV8 |
Last time you took my advice you bought an Aston Martin DBS... |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6377 ![]() ![]() ![]() |
Are you sure its not a temporary fault frank? A recycle etc a few times often clears these. if not, then maybe a fuse gone?
Radio | AUX | TV work well |
There is a catch all fuse for audio yes but there is a separate 5 amp fuse for the CD autochanger, its in the passenger side glove box fuse panel, number 40.
Can you eject the CD cartridge normally i.e. has it got power?) Discovery 4 HSE
found the fuse - it is not damaged ... i can eject the cartridge... All my spelling errorz are belong to me!
I take it once the cartridge is re-inserted it doesnt suddenly 'find' it? Discovery 4 HSE
njet |
0/10 for effort Adam. Clearly not trying hard enough. ![]() Get the battery off. Leave it 5 mins, short out the battery cables (on the car, NOT the terminals on the battery itself). Connect it all back up and try again. Should be fine. Mine does this occasionally. Dom |
thanks i will try this.... All my spelling errorz are belong to me!
update - my local dealer had just to *reflash* it.... |
