Home > Maintenance & Mods (L322) > Rear washer - should the flow of water be constant.
supershuttle
When I hold the stalk in the wash position water only comes out for 3 or 4 sweeps of the wiper - is this normal Question
Note: rear not front which is fine except that activating the fronts randomly washes the headlights, it's probably not random I just haven't figured out what's what Whistle Geoff
Post #107895 18th Feb 2012 10:04am
fronts are washed when the headlights are on and you wash/clean/flick the wiper switch.. ... - .- -.
Post #107902 18th Feb 2012 10:58am
sleepezy
Rear - same as mine! Water should flow briefly before they wipe, if not the non-return valve isn't working as intended
Front - will spray every 5 times if the lights are on
Post #107941 18th Feb 2012 2:58pm
I wouldn't mind getting any water at all out of mine. Laughing
Post #107955 18th Feb 2012 4:58pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Got rear wiper washer working..!
My dad was fitting a new starter motor today for his RR, so whilst he had his tools out thought we would have a go at fixing his rear washer. So I had a look at the guide on here but skipped a few steps, just unscrewed the motor face whilst still fitted to the car, cleaned all the brown gunk out of the tubes which were blocked solid, also picked with some long needles and voila, working rear washer..if anyones washer not working it might be worth a go before takng whole thing off,u need some v long v fine needles/wire to get right up and into the tube and into the little washer holes on the wiper..
Post #107968 18th Feb 2012 7:15pm
starman
Sweden 2005 Range Rover Vogue 4.4 V8 Giverny Green
Lolo, my rear washer doesnīt work.
Could you pls link to that guide. I canīt find it.
Post #108000 18th Feb 2012 11:02pm
@ starman
Always worth checking the wiki Wink
This one: http://www.fullfatrr.com/forum/topic9924.html
and this one: http://www.fullfatrr.com/forum/topic884.html
Should sort you out .
Post #108005 18th Feb 2012 11:35pm
