Home > Technical (L322) > Track rod end
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Track rod end
Hi Chaps
Just a quick one (I hope) Track rod end left hand or normal thread?
Got to change one later
Thanks Mine was a blue one! Smile
Post #107326 14th Feb 2012 4:11pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
As far as I remember its a normal thread. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #107708 17th Feb 2012 12:15am
Normal fella...
Craig Thumbs Up
Post #107721 17th Feb 2012 9:22am
So when would it be a left hand thread? Discovery 4 HSE
Post #107739 17th Feb 2012 10:59am
Andy3681
Sorted thanks chaps. Thumbs Up
It would not undo without damage so had to change inner and outer.
Many thanks
(some cars have them with left hand treads if i remember correctly not done one for ages so just thought i would check) Mine was a blue one! Smile
Post #107742 17th Feb 2012 11:08am
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
What was the reason for change?
I'm chasing a front suspension clunk, and have done all the front suspension, but nothing on the steering.
There is no sign of any play in the track rod ends, but running out of ideas!
Ta
David
Post #107744 17th Feb 2012 11:23am
Andy3681
Changed track rod end cause it was shot.
started as a knock from the front end when going over potholes or grids. it slowly got worse then steering was shimmying (excuse spelling) when travelling over uneven surfaces. Jacked front end up rocked wheel top and bottom fine, left and right bit of play in nearside track rod end so swopped it, it was shot when I got it off. Now all fine just a bit of suspension thump over potholes etc.
however track rod was siezed solid on inner trackrod even 24" stillsons would not budge it and if you warm them up it can be an MOT failure I am told, so ended up replacing inner and outer. Old one would not undo even in a vice with big stillsons so no chane lying under the thing at home will make sure I have an inner to hand when I do the other side just to be on the safe side.
Good luck with your investigation what I did was deliberatly run one side over a bad surface then the other to see if one side was worse as when it started it was just a general knock from the front Mine was a blue one! Smile
Post #107924 18th Feb 2012 12:55pm
