Home > Technical (L322) > Key Programming
Page 1 of 3 123>
Key Programming
Has anyone programmed a spare key using the method described below?
The reason I ask is I am collecting a new key tomorrow from LR and it will require £60 of my hard earned groats for them to programme the key to my vehicle. Being that I am from north of Hadrians Wall I would rather the £60 stayed in my pocket.
Quote:
Programming a new Key
Replacing a missing master key is quite expensive from Land Rover, try not to get sucked into the extra cost of "Dealer coding" You can do this yourself in 2 minutes by following the simple process below.
1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize.
Post #36708 18th Nov 2010 4:46pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I have read that it works but not tried it yet, i need a new key so i will watch this post with interest. At the very least try it in the car park before getting them to do it.
I lost my key on a stag do about a month ago, my missis was so pleased when i rang in the morning to explain she needed to drive 150 miles to drop the spare off.... Rolling with laughter
Can you tell me more please, how much did landrover charge for just the key and can i buy a new over the phone with my vin number or you got to take the log book, id in etc.
Thanks 2004 black Vogue TD6
Post #36724 18th Nov 2010 6:06pm
You need to go into the dealership with your V5 and a driving licence or passport as proof to order a key. The cost is £168.50 + VAT, although I never paid for mine, the person who sold me the vehicle has paid for it.
What I am unsure of is do I need to re-programme my old key at the same time as the new one, or just the new key?
Post #36729 18th Nov 2010 6:28pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
£165 incl. for mine Mr. Green
Tried the above and all it did was stop the original from working Big Cry
Tip to the indie with proper LR machine me thinks
Post #36738 18th Nov 2010 7:31pm
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
it worked for me Very Happy
Post #36747 18th Nov 2010 7:48pm
Did you only programme the new key or all keys?
Post #36780 18th Nov 2010 10:17pm
nbunney
Which key did you use for:
Post #36782 18th Nov 2010 10:24pm
I have the key that I received with the FFRR which I am using to start/drive the vehicle and I have ordered a spare key which I will collect tomorrow.
When I programme in my new key will I have to reprogramme the old key?
Post #36783 18th Nov 2010 10:33pm
daveo
hi this is how it works as i have done it.. you can reprogram the blip and it will open the doors and lock the doors but will not start the car. as said in post before you can NOT reprograme a used transponda chip,not your self or at a dealer, it will be a new reprogamed one and will have to come from the dealer. they have you buy the balls.and best of all you have to pay up front for te key... V8 facelift Range Rover Autobiography 22" wheels.
Post #36789 18th Nov 2010 11:30pm
Thanks for the info guys, I'll speak with LR tomorrow when I collect the key
Post #36801 19th Nov 2010 1:19am
When a new key is ordered from LR it comes ready to start the vehicle, the transponder is already paired to the anti-theft system of the vehicle and the new key will start the engine. (this was what I suspected).
The new key however will not unlock or lock the doors, this has to be done with the method shown in my earlier post. Both keys have to be done at the same time as per my earlier post as only doing one knocks the other out of sync.
The only thing I can add is to ensure that you only put the ignition to position 1 when you are going through the procedure. If you put the ignition to position 2 the procedure will not work.
This is for 2002-2006 vehicles, newer vehicles have to be plugged into the computer
Hope this helps
Post #36835 19th Nov 2010 2:41pm
letsavit2
Thanks for the confirming this. Wink
i need to get around to doing this very soon, before i lose my only set. 2004 black Vogue TD6
Post #36861 19th Nov 2010 4:32pm
Remember the key to position 1 only or it won't work
Post #36901 19th Nov 2010 6:26pm
ahebron
New Zealand
Christ thats a bargain.
I was quoted NZ$1100 for key 3 weeks ex UK. I will leave the conversion rate to you guys. What Censored me off is I have a nice new housing, I have a good working mechanical key, I have a good working transponder what I do not have is a good working circuit board.
I have tried synching this key as it was the original working key when I bought the car, the spare had a flat battery. Now it occasionally works while the spare goes great guns.
Is it possible to just change the electronic bits without going through all the hassle of a key and transponder?
Adrian
Post #108022 19th Feb 2012 8:20am
For that price I'd be calling Dan to see if he could help out Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #108024 19th Feb 2012 8:30am
Page 1 of 3 123>
