Home > Maintenance & Mods (L322) > Xenon headlight
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Xenon headlight
Help!
LH headlamp went a bit flickery, then after switching off lights hasn't come back on. Swapped bulbs round - its not the bulb. Likely to be the ballast?
I've scored one on the bay for £45. But until it comes, any other ideas?
Post #108112 19th Feb 2012 9:02pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Does sound like a ballast- they need several thousand volts to ignite the gas. This would explain the flickering.
Good luck!
Post #108118 19th Feb 2012 9:43pm
Simes
Cheers Happy.
Just hoping I've not wasted £45 because it's a hidden fuse!
Post #108132 19th Feb 2012 10:42pm
Simes
As another question - is there a seperate igniter/start unit or is that build into the ballast? i.e. should I get a starter or igniter as well?
Post #108177 20th Feb 2012 10:51am
pretty sure the ballast is the igniter/starter... ... - .- -.
Post #108181 20th Feb 2012 11:31am
Stephen.125
^^ what Scarey said.
Post #108182 20th Feb 2012 11:32am
Simes
Hope so - although I've seen another part number 307 329 059 which may or may not be a seperate ignitor...
I'm confused and worried - or worried and confused, I'm not sure which.
Post #108184 20th Feb 2012 11:40am
