![]() | Home > General > Rear Screen - do you have a lower trim? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871
should be one ...its between the bottom of the glass and the top of the metal part of the upper tailgate.. ... - .- -.
| rich_959 Member Since: 13 May 2011 Location: East Yorkshire Posts: 64
Yeah, that's the one, cheers Scarey. Mine doesn't seem to be completely right after a warranty tailgate replacement and I'm just deciding whether to ask for the trim to be replaced or not.... I think I'll let sleeping dogs lie and put up with it. |
hopefully it wont leak water.. |
Fairly sure it's just a cosmetic piece of trim, rather than forming part of the seal. You had to place doubt didn't you!! |
| simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650
rich, I have a 57 plate 2008MY model and it doesn't have a trim at the bottom of the rear screen |
pic...... seems to keep the glass from knocking the metal..
Cheers Simon. Hmm. The 2 cars I've seen without the trim were 57 plates (and yours makes 3) and mine is an 07 WITH the trim. Wonder if it's a variation across the years. I'll be looking at every car I see now!! |
Thanks for the pic Scarey, that's the one. On the cars I've seen without the trim, there seems to be a bit of clearance between the glass and bodywork. The trim on mine (and as per your pic) just looks like a finishing strip to match the way it's finished on the side windows. So has it fallen off these cars, or been removed, or intentionally omitted at the factory I wonder.... |
i'll be looking at them now.. |
| Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746
Here's the back of mine to start you off with this weird hobby of seeing who does and does not have a finishing strip |
Ha ha, what have I started! Should have made it a survey |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
The finishing strip was dropped on later models for a cleaner fresher look.
