![]() | Home > Technical (L322) > Jacking - a simple query |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
Never jacked up the L322. On my P38 though I left it in access mode with the boot open as this prevents any movement in suspension. Present :2008 TDV8 HSE
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
For the rears, I put the hydraulic jack under the air spring with the car in standard height and put an axle stand under the side jacking point for safety. |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
in any height, if you jack it up it will just use up all the suspension travel. Annoying.
| rads Member Since: 04 Sep 2011 Location: Herts Posts: 157
Nope. Airsprings always push down, cant "suck" up. Whatever you do, the suspension will droop fully as you jack the wheel up. If you start at access, you will have to lift past normal, to high, and only then start to lift the wheel. Start jacking from high, less effort for you. David |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Decent trolley jack under the lower suspension arm. Never failed me yet. |
| MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471
Can you not lock out the suspension from inside the car (like I have to when going into a multi-storey car park) "On first name terms with my local Dealer......now."
Yes you can but I'm not sure if this works for wheel changing.
yep - have to agree - I keep an original LR bottle jack in the car (has a welded cup on the top to stop it slipping) that has enough lift to raise the car easily. I definitely don't trust the scissor jack. Must have a look for the 3ton trolley that is often mentioned on here. "On first name terms with my local Dealer......now."
| JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 269
A 3 ton trolley is the key. I bought the Costco one not so long ago. It took less than thirty minutes to change all four tyres and I wasn't rushing. What would be helpful is some means of easily lining the wheels up with the hub and I may give Red Bull a run for their money. 2021 3.0 P400 Vogue
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
Use a trolley jack, my scissor collapsed at its first outing dumping the car on its disc |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
as it happens, i had a blowout on the december salisbury plain trip and the scissor jack worked remarkedly well..but i think i was just lucky cos they are |
| Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543
Well in the end, I put it at max height and used a trolley under the suspension. Interesting to read the different theories on height for jacking though. No longer FF owner but still interested. Present car Jaguar XE
i really dont think it matters what mode the suspension is in ..i've jacked in all 3 and had no problems...it doesnt say in the manual either .... |
I know, just wondered that it might make a difference to how much you need to jack to lift the wheels off the ground. It isn't really relevant if you use a trolley jack, but using the flimsy scissor jack in an emergency, you wouldn't want to have to lift such a heavy vehicle too high. No longer FF owner but still interested. Present car Jaguar XE
| All times are GMT |
