Home > Technical (L322) > Hot Diff and Leaking Diff Breather
When my car was serviced I asked them to double check the front diff, as ever since I had the front driveshafts replaced (as part of the Range Rover Assurance Programme) it had developed a leak -which had subsequently been fixed a few times by the dealer. Evil or Very Mad
Anyway, it appears that small amounts of oil are being forced out of the front diff breather pipe in the engine bay near the oil filter housing. The dealer says the diff must be getting too hot and this is forcing oil out. I'm no expert but I would guess that if the diff cannot breathe (due to a partially blocked/kinked breather pipe) then this would cause overheating and thus forcing oil out the breather pipe.
The dealer wants to 'investigate' with about 5 hours work dismantling the diff altogether to find out why it might be overheating. I think that a quicker and cheaper potential fix would be to replace the breather pipe assembly completely, to see if this fixes the breather issues and then any potential overheating. If it happens again then OK, time to dismantle more stuff, but replacing the pipe can only be an hour's work at most.
Anyone with more knowledge on these things able to advise? Discovery 4 HSE
1993 90 Tdi
Post #6626 31st Jul 2009 11:03am
I saw this on the 'other' forum, need to check mine but wonder if this is my issue?
http://www.rangerovers.net/forum/viewtopic...er#p237411
"If the leak started immediately after having the front propshaft/diff. updated it might be worth checking that the front diff. breather pipe adapter is orientated correctly (see diagram below). The straight edge should be facing the front of the car. This issue was the subject of a Technical Service Bulletin "Oil leak from front differential breather pipe" dated May 2007. If your adapter is incorrectly orientated then a replacement differential is required as trying to reorientate the breather adapter would result in housing damage."
The Service Bulletin codes are as follows:
Oil Leak from the Front Differential Breather Pipe LTB00049
Front Differential breather Pipe - Service Item available - LTB00206
 Discovery 4 HSE
1993 90 Tdi
Post #6627 31st Jul 2009 11:14am
Coz the simple and easy route is not obvious to the Censored ...............
Just as well God gave us an Arse coz thats what most of these " TECHNICIANS " talk thru ...... Whistle
Post #6628 31st Jul 2009 1:53pm
jope
Norway 2003 Range Rover HSE Td6 Java Black
RRUK, did you find the problem causing the diff oil leak?
Post #10945 11th Jan 2010 9:47pm
Jope, not really it seemed to stop. I suspect the breather was the issue, there is an LTB about the positioning of the breather pipe.
Check out the Technical sections ticky pthread about L322 GTR headers, its in there somewhere! Discovery 4 HSE
1993 90 Tdi
Post #10947 11th Jan 2010 10:04pm
jope
thanks, have seen it.
Just wondering as we now in Norway have had down to -35 degrees and two FFRR has got leak from the front differential. Hopefully the leak will stop when the weather gets warmer, but was curious if you had found out the problem on yours
Post #10950 11th Jan 2010 10:09pm
is it leaking from the breather pipe in the engine bay? Discovery 4 HSE
1993 90 Tdi
Post #10951 11th Jan 2010 10:26pm
jope
it's been to cold so I haven't been investigated to much.
but it seems like it leakin from the breathercap on the differential or another place from at the differential Rolling Eyes Right side looking at the car from the front.. (LHD)
Post #10954 11th Jan 2010 10:37pm
