![]() | Home > Technical (L322) > Suspension fault again |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Last year, I had a fault message: air susp. Inactive. The lights went out on the control knob as well. I took it to Colliers in Birmingham, who reset it for free. Their technician said he hadnt seen this particular fault before, which added to the confusion.
Knife the airbags |
Cant drop the suspension- nothing happens when I twist the controller or press the button on the door 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
Even after u disconnect reconnect battery? |
Yep. Disconnected it, left it for half an hour then reconnected. Turned steering from left to right but hasn't cleared it and still no LED's on the controller 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
I had something similar. The maindealer wiped the fault codes and all ok since |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
I would try a new battery if not relativly new already after that i would put a new complete compressor assembly in the boot as most faults stem from lack of pressure or faulty valves on compressor and then go from there as for what a dealer will charge for diagnostics and repair will cover a new compressor onto no6 Range Rover
Or save yourself the money for a dealer visit and purchase a diagnostic tool for yourself. There are a couple of people here on the forum selling them... |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1554 ![]() ![]() |
+1 finds out the error and take it from there.
Who's selling the diagnostic stuff? I'd probably go down that route. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
benjj Member Since: 27 Feb 2012 Location: North Yorkshire Posts: 116 ![]() ![]() ![]() |
It is worth remembering that to do the wheel alignment thingy (lock to lock) it needs to be before you move away after starting engine.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
I have Steve MFr's IID Tool.
I hit the wrong smiley yesterday... ![]() Was supposed to be this ![]() http://gap-diagnostic.com/products/iidtool.html And here our distributor http://britpart.com/newsstory.asp?PageRef=10&NewsRef=69 ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Price? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
