![]() | Home > Maintenance & Mods (L322) > My experience of a Td6 remap |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1230 ![]() ![]() ![]() |
Great write up. I agree that it is one of the best things you can get done to the Td6. I was lucky that mine had it carried out by a previous owner. It makes the Td6 nimble, smooth shifting and sporty (for a Range Rover). Tom
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35762 ![]() ![]() |
if you're talking about a company called rapid remap , then my experience was the opposite .... |
Stan you should go back to them as model specific tunes do not necessary suit every car of the model they are designed for . I'm pretty sure if they are any good they will have a number of maps for the TD6 one of which will suit your specific car. Present :2008 TDV8 HSE
it was a while ago now googsy and tbh i lost confidence in the company ... |
benjj Member Since: 27 Feb 2012 Location: North Yorkshire Posts: 116 ![]() ![]() ![]() |
I'm not absolutely positive it was Rapid Remap, my local indy (who has done a lot of these and is well regarded) told me ages ago who he used. It could have been another supplier and I'm just remembering wrong. I'll double check who the map was done by.
i just wonder how difficult it is to do these remaps.....plug into the obd port, connect to software on laptop, play with settings and then upload back to car..
Yep, I don't think the actual upload/change is any kind of work at all. As for writing the map itself, I really don't know. |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
As you demonstrate Stan - that's the easy (and cheap) bit. It's the cost of a Dyno to test the setup and access to the maps in the first place - and then the skills to tweak them correctly - and not (like some places) just upping the fuelling and boost pressure and hoping for the best. |
didnt have a dyno test when i had mine done ....they did say that they tweaked my map but i wonder if there's standard maps for performance .economy etc... |
I thnk I'd rather have it done on a dyno - then the maps can be tweaked to suit the car and results of the map changes tested and proven! |
funny enough my re-mapper said the same thing except for more mpg rather than performance.. |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
I've read these type of 'tuning' posts for a while with a 'shall I or shan't I' outlook - but weighing things up about the fragility of the TD6 gearbox i've decided against going down that route |
Yep, I can understand that.
