![]() | Home > Technical (L322) > I want to buy a ride height module |
Your only choice is an IID Tool... Search the wiki...
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Sounds to me like you want to reduce the ride height by as much as possible, then go into access mode whenever you park. The former can be done with an IID tool, the latter needs to be done with the dealer diagnostics, fault mate is it? |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Couldn' he modify his height sensors brakets, à la Disco III ?
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
From the IIDtool userguide :-
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
thats the tool then....contact stevemfr simon... ... - .- -.
You can do much the same using the RAC (All Comms) along with a tape measure and calculator when you redo the calibration.
If you do not want to do any diagnostic work, then the EASControl is more than enough to do the job. It has the same programming ability for the EAS as the IIDTool and fault read/clear on the EAS (no other systems, tho). And the cost is about the same as many lowering links that Joe mentioned which allow a mechanical lowering of the RR. And you don't have to crawl under the vehicle or can change heights in about 2 mins from inside the vehicle.
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 ![]() |
I checked out the EASControl pricing is around 180 im wondering though , would 22mm drop on 20 inch style 11 rims look that different?
i think you need to go to the lowriders'r'us forum.... |
