Home > Maintenance & Mods (L322) > Fitting 06+ mirrors on pre 05
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Hi
Has any one else done this?
Ive fitted a set of 08 side mirrors to my 04 pre face-lift td6,
I thought / think these should be a straight swap.
anyway fitted them and all controls work perfect heated/memory etc
but not the folding in, my old mirrors had the limit switch problem which i fixed before swapping over
so i know the car wiring is fine.
Ive take these 08 mirrors apart to find the limit switches, but there is just two wires going in to the fold motor
I think one of the motors may have had a bash?
just wanted to be sure they should work before i buy a new motor
Thanks RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #110824 4th Mar 2012 5:30pm
daveo
you need to change the switch pack 06 on, as well if you want them to fold in. V8 facelift Range Rover Autobiography 22" wheels.
Post #116687 6th Apr 2012 9:34pm
+1 Thumbs Up window switchpack needs to be late too...
Craig Thumbs Up
Post #116702 7th Apr 2012 12:35am
Jr-auto-electrics
Cheers lads ill see if i can find some on flee bay.
Ive made two little circuit boards up and fitted those at the moment and they work fine,
original is always best.
thanks for the reply's RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #116748 7th Apr 2012 2:14pm
daveo
there's is a member on here who has done a circuit that folds the mirrors when looking the car, would be cheaper then a switch pack plus they will fold in when locked... V8 facelift Range Rover Autobiography 22" wheels.
Post #116780 7th Apr 2012 11:29pm
Jr-auto-electrics
Just priced up the packs LR020110 (drivers)£30 and LRO12038 £20
so not to bad really, plus i want the button to work inside the car
this wouldn't if not changing the switch packs.
I posted a reply to that guy but never got any response from him.
Is he still producing them?
Id like to fit one of his kits with a over ride switch.
Have you got the guy ID name to hand. Thumbs Up RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #116787 8th Apr 2012 9:39am
Jr-auto-electrics
Forgot to add is just the drivers side or both packs to change RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #116797 8th Apr 2012 11:02am
daveo
just the driver pack.i thought they would be much more then that.... Shocked
heres a link to his post on the mod
http://www.fullfatrr.com/forum/topic10155.html V8 facelift Range Rover Autobiography 22" wheels.
Post #116805 8th Apr 2012 12:06pm
