Home > Maintenance & Mods (L322) > egr blanking kit for td6
Page 14 of 15 <123 ... 131415>
Hmm,
I wonder if its worth going thru this and on the first post having usernames, their initial MPG for normal trips and then their after, then their after long term??
IE
Kingpleb,
22mpg
32mpg
27mpg
(ps i havent done this on mine they are just examples!) FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #104149 28th Jan 2012 7:14pm
sounds promising tom..it will take a few journeys on different routes to get a proper average ....mine has defo improved and those few extra mpg's do help in these difficult economic times... ... ... - .- -.
Post #104150 28th Jan 2012 7:15pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Another wee trip to B and Q, 20 miles 29mpg average.
Will report back after a few hundred. Do about 20,000 a year so wont take long.
T
Post #104161 28th Jan 2012 8:15pm
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
TD4 kit does NOT fit
Just for information, I ordered the TD4 EGR kit from ebay as it was a bit cheaper.
Imagine my delight when i realised it did not fit!!
The plate attaching to the exhaust hose is too long which means it would not marry up to the manifold. It was only about 10mm out - but too much to bolt it on.
I contacted the seller who confirmed the part for the TD4 and TD6 are slightly different!
Anyway sold it on ebay and got the allisport one.
Fuel economy 23.5 aound town so far (usually about 21.5)
So far so good
BTW - if you do try cleaning out the original egr valve - beware - I wandered into the house and upstairs to get a torch and left tarry crap all over the stair carpet. I reckon the cost of a new carpet is going to offset any money i save on diesel..........
Post #108330 20th Feb 2012 10:00pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Hi Aurrian
do you have any other economy modifications ie map/chip or just the egr valve replaced?
thanks Mine was a blue one! Smile
Post #108372 21st Feb 2012 10:01am
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
I am going to order an alli sport one on eBay, but just want to confirm the install is straight forward and easy access? I saw the guide on wiki but I just want to make sure I don't have to take a million things apart/off before I can get at it..
Post #108408 21st Feb 2012 2:09pm
the only problem i had was the weird jubilee clip but other than that it was straight forward... ... - .- -.
Post #108412 21st Feb 2012 2:30pm
Andy3681
About 20 mins unless you try to clean out the inlet manifold at the same time. Bottom left allen bolt can be tricky but easier when you fit new part as you can see it then.
You must remember to blank the vacuum hose (blue I think)
Have fun Mine was a blue one! Smile
Post #108417 21st Feb 2012 2:44pm
Lolo
Thanks lads I'll fire away so.. The allisport one has a little blanking nipple for the hose..
Post #108418 21st Feb 2012 2:46pm
Aurrian
Hi Andy
I have a pro-bitz tuning box too. I have had that since i got the car, so not sure what it's like without it!!
I got it on ebay for about £100.
Cheers
Post #108453 21st Feb 2012 5:20pm
Andy3681
Thanks Aurrian
I just wondered because those figures are about or slightly better than mine but MPG is such a huge thread and also bag of worms on here with so many claims and counter claims. I seem to do about 34/5 on a motorway (which would be in line for the 10% claimed by my box at 60), 33 at 70 not sure round town because it only does a daily of three miles so somewhere around 18/19 feels about right. If i do a bit more of a local run maybe low twenties not that bothered about mpg cause if you want a rr you cant worry about it but just like to know its about right.
It would be good to know if people running re-maps or boxes find the engine noisier in useor notice any increase in smoke when they floor it ?
Ta
Andy Mine was a blue one! Smile
Post #108505 21st Feb 2012 9:17pm
Lolo
Nightmare....!!
So went to fit the allisport blanking kit. Should have been 5 min job, nope 5 hour more like. The bottom left bolt was not budging. Dad decided to saw off old valve to get better access. Head on bolt was worn, wanted to scream several times, but eventually lost the head with the vice grip and got it off..the relief. Now one question the hose, I put i blocked it off by putting it onto the nipple of the blank kit. I never thought to secure it on, what happens if it comes off?
Post #110713 3rd Mar 2012 8:42pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
it shouldnt come off as it works on vacume not pressure.
Post #110909 5th Mar 2012 1:09am
ahebron
New Zealand
I fitted one of the cheap Britpart EGR blanking kits to my 2003 TD6 HSE. While I had the EGR off I decided to clean the inlet manifold which had approx 5mm of soot buildup lining it. What a job that was I ran it through a parts cleaning solution then hot soapy water and finally washed it in petrol. But what a difference it made, no longer trailing large black smoke clouds under acceleration and the engine seems to rev freer. It went to 4500 in sport mode under rapid acceleration the other day.
Though I do agree with Aurrian that the stains on the carpet take a while to remove but a powder carpet cleaner is your friend. Also works on the FFRR carpets Very Happy
Adrian
Post #110913 5th Mar 2012 7:30am
just over a year on and i still get slightly better mpg and no ill effects , so a sound investment me thinks... ... - .- -.
Post #136154 16th Aug 2012 9:43am
