![]() | Home > Technical (L322) > Unexplained battery discharge???? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
Good news, funny how a dying battery can cause so many odd faults. Discovery 4 HSE
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Low Voltage causes more than a few
jediwhite Member Since: 17 Nov 2009 Location: Ballina Posts: 1 ![]() ![]() ![]() |
Hi
my local garage fitted a Bull battery, seems ok to me!
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
Doesn't just affect the Range Rover - many other brands suffer too when the battery is passed it's best. |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
I have had flat battery problems, the first 3 years ago was caused by the relay for the headlamp wipers coming on and allowing the wipers to run the battery down. I wondered why they were parked across the lights at times. New relay cured it.
If the frost freezes them they can get out of sync and get confused. Although I've not heard of that causing battery drain, wipers pointing to the sky is common in summer.... Pop the fuse back in just to see if they reset. Dan ![]() |
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 ![]() ![]() |
Good advice RRUK.
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
i had the dreaded bty problem last summer, i went to kwik fit and some gobby young lad measured the battery and said it was ok
Put the fuse back in this morning and when I walked round the front the wiper had parked.
mmuhlen1 Member Since: 21 Feb 2010 Location: Illinois Posts: 2 ![]() |
Im also currently having this battery drain issue. Replaced battery, still won't start after a 1 day of sitting. Pretty sure the alternator is working fine.
you said you can hear a fan like noise coming from the centre console this could be that the final stage fan is not being told to go to sleep and or waking up intermitantly and draing your battery. the easey way to check is to
Yes, I hear a slight humming noise from center console. Its very quiet.
yep thats what happened with mine and i change the HVAC (bit of a |
