![]() | Home > Technical (L322) > Noise when I reach 55mph and up - Anyone? |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
If you steer from side to side, swinging the car, or cornering, does the noise change as the weight of the car is transferred from side to side? Previously..
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Can't say for certain until I'm out tomorrow but from memory today I don't recall it changing tone. Its silent to 55 then comes in and is a constant noise from outside the car until I drop below that sort of speed again.
Could it be wind noise of some sorts? Any loose trim on the bodywork? Previously..
I've had similar before and it was a loose scuttle tray.
Well it had a new altenator at the local LR dealers last Friday, plenty of parts to remove and the noise is evident now |
The cornering at speed with the radio off will give it away if its a bearing fault.
The noise didn't change when cornering, that said I didn't do much cornering on the m/way.
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Did you get to the bottom of this? I have a drone, possibly a bearing on the front but I can't feel anything when I rock the wheels ... Although they are that heavy, maybe hard to tell. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I've got the same or similar whine. It sounds to me like a bearing. Difficult to track down as it is only heard from 30mph plus and then over 70 can't hear it for wind/tyre noise. It is a very stable, high pitched, low volume, whine. Not affected by steering as far as I can tell and not affected by gears. Perhaps rear diff? 2012 5.0L S/C
I have the same type of noise on a specific bit of road, it sounds like a resonance typical for tyre noise. This bit of road is bricks not bitumen. It is only the one bit, the rest of the same road no issue. Will keep an eye on what speed it is at next time. I think it is just a freaky but rare combination of the resonance frequency of the tyre "blocks" and the way the bricks are laid on that bit of road.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35849 ![]() ![]() |
i concur with Eugene that it could be tyre noise... ... - .- -.
I get this with the Nexens first thing I noticed. Present :2008 TDV8 HSE
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3815 ![]() ![]() |
Also had this, it was the washer spray & elect cable resonating against the scuttle in front of the battery. I also get a bad hum on certain roads from the tyres but mine are Genersl AT so its expected |
