![]() | Home > Technical (L322) > Front suspension |
snugg Member Since: 16 Jun 2010 Location: Maryland Posts: 29 ![]() ![]() ![]() |
I change the passenger side strut last night and the noise appears to be gone and the strut is as tight and the drivers side. I guess I'll be changing the drivers side in the next couple of weeks when I get some time. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
thats good to know ,thanks
blench99 Member Since: 18 Nov 2011 Location: northumberland Posts: 24 ![]() ![]() ![]() |
mine is doing the same thing and i've disconnected the n/s anti roll bar link and noise goes away but the bag does seem soft compared to o/s which i changed last year. i think that the noise is being amplified by the bag being soft. new a/roll link fitted, bottom ball joint and bottom arm. ideas? |
If the air bag is soft, the strut may be contracting further than it is designed to do and the anti roll link may be hitting the wheel arch or hitting something else creating the noise. I am not sure if the strut it self makes a sound when it is resting to the bump stops. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I've had a few Air suspension errors for a while an the code is getting is "too much energy req to regulate front axel". I emailed storey and he said it was the front bag gone and compressor was working to much to keep it full. I've got not change in height etc when stationary so decided to leave untill it shows other signs. But apparently that's the error you will get if you bag is fubar. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
