![]() | Home > Maintenance & Mods (L322) > condensation in rear lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35818 ![]() ![]() |
best get some goldfish then..... |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
anyone who doesn't want to drill can try putting in a silica gel pack XYD500010
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1240 ![]() ![]() ![]() |
One of my lights has shown a little fogging too, I might try the silica option, as long as there is not much water in the casing. Tom
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
The only problem with putting silica jel packs in the units is if the leak persists that causes the condensation the silica jel becomes saturated and requires drying to restore it moisture absorption properties.
think the gel packs were only designed for misting up problem, not full on leak/water in lamp unit You can paypal direct using - www.paypal.me/duckworthparts
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3810 ![]() ![]() |
I use silica gel in ammunition and gun cases and recharge them / dry them out every 3 months in the aga overnight |
Where do you put the silica gel packs in light as they are sealed? Into where bulbs go? Present :2008 TDV8 HSE
Shropshire lass Member Since: 03 Oct 2011 Location: Shropshire Posts: 58 ![]() ![]() ![]() |
Big help ! Wasn't sure what to do re misting up on drivers side rear lights.
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
or they could just make the lights work as they should? Range Rover 4.4 V8 Vogue |
^^^ couldn't agree more.
Where do you put the gel packs exactly ? Present :2008 TDV8 HSE
SupaCharged Member Since: 30 Dec 2011 Location: England, Herts Posts: 29 ![]() ![]() |
I saw a good tip for this on another car forum, they were using fishing line tied to a silica bag , drop this into via one of the bulb holders and you can remove it as and when you please. |
