![]() | Home > Maintenance & Mods (L322) > first issue. |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
What color is the oil or smell? I thought I had oil leak until I took a smell and it was diesel from high pressure injector on td6 tho |
Are you sure its not from aircon condensation quite normal. Present :2008 TDV8 HSE
paul r Member Since: 27 Feb 2012 Location: Nantwich Posts: 217 ![]() |
Nah, definately engine oil. Looks like it's coming from the left hand side of the engine (looking from the front). I'll have to get the undertray off I suppose to see where it's coming from.
well if its engine oil leak and its a nightmare to fix or v expensive id get a good stop leak additive.. i know lots of people say not to touch the stuff works for many others.. |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
My SC dripped oil from the transfer box and was fixed under the LR extended warranty last year.
Transfer box is on the *back* of the gearbox......so no, it's not under the engine.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Get a spare can of oil and just keep it topped up. |
Well after further inspection, its not that bad. I have a gocar warranty, I might just wait until its next service and get it looked at then? Will an aftermarket warranty cover leaks?
I decided to go back to the dealer. They are going to sort it out for me. Too right! |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
You should have bought mine, there's no leaks! |
I don't regret buying the car.....an oil leak isn't the end of the world. Could be worse! |
Fingers crossed you don't live to regret those confident words! |
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 ![]() ![]() ![]() |
Having been around Land Rovers all of my life, I've noticed that the only time they dont leak fluids is when they're dry!
