Home > Technical (L322) > Locking wheel nuts
Andy
Locking wheel nuts
Two questions guys:
1) Just went to remove the wheels to change the front brake pads and discs and I cannot find the wheel nut adaptor anywhere- are they available to buy?
2) I will be fitting 20" alloys after the brakes have been done. The seller sent all of the new wheel nuts and there are two locking wheel nuts and the adaptor missing. Do I need a new set or can I buy two locking wheel nuts and an adaptor?
Cheers 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #11180 17th Jan 2010 1:49pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
If they are genuine LR parts you may be able to order the replacement from the dealer.
If not then i'm afraid its time to crack out the drill and replace them for new ones. TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #11184 17th Jan 2010 2:20pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
are yours on your vehicle the pre or post my06 if they are pre i.e posibly original equipment you can go to the dealer and with the vin no they will be able to get the correct key as they are alphabetically numbered on the top of the lock nut if not original eigher i can ask my good friend at droitwich L/R parts if he can try all the diferent combos of lock nut on yours therefore you might not need to destroy them to get them of Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #11188 17th Jan 2010 4:12pm
Andy
They are splined and have black plastic caps on them. Before I go to the dealers, it's not hiding somewhere is it? I can't find it, and was just wondering if it has some dedicated cubby hole somewhere on the car. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #11222 18th Jan 2010 12:03pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Noddy
Normaly kept in spare wheel whell back right hand side by the wheel chocks in a grey foam holder
Post #11227 18th Jan 2010 12:29pm
Andy
I can see the wheel chocks (right hand side of wheel towards tailgate) but no grey foam holder and no sign of the adaptor. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #11235 18th Jan 2010 4:54pm
Andy
Bought a new one from LR today - £11.95. At least I can get the wheels off now. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #11362 21st Jan 2010 2:47pm
speedymarktd6
did they sort you out at droitwich LR Thumbs Up onto no6 Range Rover
Post #11368 21st Jan 2010 6:58pm
Andy
I went to my local one in Stourbridge mate. Got some discount as well 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #11377 21st Jan 2010 10:54pm
