![]() | Home > In Car Electronics (L322) > remote key fob HELP! |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Sounds like your key needs reprogramming. Follow these instructions ......it worked for me after a couple of goes!
filthyliam Member Since: 01 Aug 2011 Location: Lincolnshire Posts: 81 ![]() ![]() |
ok thanks for this when you say "after a couple of times" i take it you did it once it didnt work and you had to try the process again then it worked?
Just wasn't quick enough the first go. The only reason I did this is because my spare key did as yours does when I first got the car. ie everthing worked except the central locking. Here's the link I got it from:
Thanks for your help Jonno it worked first time ! just discovered that the spare key is doing the same so will do the same thing with this
Excellent..........Beats a trip to the stealers |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
just to add, u have to sync all keys at the same time, regardless whether one works or not.. |
dan457brfc Member Since: 24 May 2012 Location: portsmouth Posts: 6 ![]() |
Jonno,
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
Hi guys,
Sounds like a wrong key to me.
stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251 ![]() ![]() ![]() |
Possibly the key has never been programmed with your rover I just got a brandnew key from LR and thought I was being smart trying to program it myself but it wont turn in the ignition (it works the locks) there must be something with it having a new transponder F**K IT you only live once |
your new key is missing the transponder or it has not been programmed, that's why you cant turn the key as it does not see the transponder chip... V8 facelift Range Rover Autobiography 22" wheels.
No offence but I'm pretty sure that's what I just said LR wouldn't have sold me a key with no transponder F**K IT you only live once |
i think you will find land rover will not sell a uncoded key, if the key was brought for your vin then ether it was not programmed correctley or it has been programmed with the wrong code, has your ignition been changed.. V8 facelift Range Rover Autobiography 22" wheels.
You can buy a key from LR uncoded if you know the correct people (i did say I thought I was being smart to try and code it myself) I now have a visit to make and get all my keys recoded £60 from LR F**K IT you only live once |
