Home > Maintenance & Mods (L322) > Lower tail gate problem
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Hi everyone,
I can't open the lower tailgate, it sounds like it's unlocking or releasing on the drivers side
But not on the left side, any ideas on how to solve this,
Really struggled today transferring stock,
Thanks in advance
Sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #111020 5th Mar 2012 5:11pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Not sure on the fix, possibly need to adjust/lubricate the locks.
A work around though is that you can manually release the lower tailgate. if you slide you and down the edge of the tailgate towards the lock you can feel a paddle. Push (I think) this and the lock will release.
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #112353 11th Mar 2012 1:34am
stevegt
Post #112354 11th Mar 2012 1:35am
The motor gears for the lock solenoid have probably quit on the side that isn't making a noise Sad
It's not too bad a job if it has.
Take the top plastic trim off.
Then the 2hex bolts holding the outter lock to the lower tailgate on that side, note one holds the check strap as well!!
Then remove the carpet panel gently, I think it slides towards you a little (as your stood looking into the car)
Then the lock motor just needs disconnecting from the loom inside and new one plugging in and setting in.
Hold it in place as you place the outer black mechanism in place and then the first top bolt.
Just wind it in a bit and then do the lower one to hold things in and then tighten it all up Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #112361 11th Mar 2012 7:35am
salb
Hey KP,
Actually I found a way of opening it for the moment. When I have opened the upper boot,
When I press the unlock button on the lower gate, I have to press the plastic clip just above the door lock,
U can see this when the lower gate is open, I was really struggling as I am always loading up.
After I do my titivating, then this is on my long list of things to do. Thumbs Up Thumbs Up
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #112369 11th Mar 2012 10:00am
I have to do the manual unlock for both sides at the minute as both mine are not activating Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #112372 11th Mar 2012 10:40am
