![]() | Home > Wheels & Tyres > "e" mark..? |
Do you often run with a load in the back or just yourself and 1-2 copilots??
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
Thanks |
Tbh I run mine just below the max most of the time as I carry speed into corners which keeps wear even enough |
Is this what you are meaning Lolo ….
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35686 ![]() ![]() |
not pirelli lolo, but general tyre info that might help..
Thanks guys I'll have to get under car to have a look at the other side of the tyres so..the e is on one tyre on the outside so I am assuming the marks are on the inside of the other ones, please g0d.. |
No the e mark is on all the tyres on the outside , you don't need to get under the car , |
Well if that's the case I'm well p |
Right you are starting to lose me , on all my four Pirelli's the "e" mark is on the four separate tyre walls of each tyre …. if it is marked on the inside i don't know but at a guess i am thinking it should be ….. |
Ur easily lost so.. |
Yes Mick, get your ass under the FFRR and check your e-marks |
Check the inside's , you having a Giraffe , |
Ah go on, are u not curious..? |
No …. |
