Home > In Car Electronics (L322) > in car camera/recorder
just had one delivered and will be fitting it in the next few days..i'd like to hardwire it so that it'll start when i switch on the ignition ..
my thoughts are to put the ciggy plug connected to a female socket into the glasses cubby hole but where to get the live feed..any ideas appreciated.. ... - .- -.
Post #112521 11th Mar 2012 10:08pm
A1GSS
Try the handy "search" feature:
http://www.fullfatrr.com/forum/topic10013....=live+feed
Very Happy Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #112539 11th Mar 2012 10:35pm
Laughing
i'm aware of that, its a live /ignition feed by the glasses cubby box by the rear view mirror that i need....should have made that clearer.. ... - .- -.
Post #112540 11th Mar 2012 10:37pm
A1GSS
How about this one on Disco3:
http://www.disco3.co.uk/forum/topic65240.h...2Bblackvue Graham
____
Post #112541 11th Mar 2012 10:44pm
A1GSS
This is a bit of a worry though:
 Graham
____
Post #112542 11th Mar 2012 10:45pm
just on there at the moment graham having a browse.. Thumbs Up thanks Thumbs Up ... - .- -.
Post #112543 11th Mar 2012 10:47pm
A1GSS
Let us know when you figure it out... if I keep the FFRR I'll get a blackvue. Graham
____
Post #112544 11th Mar 2012 10:55pm
will do,,.. Thumbs Up ... - .- -.
Post #112545 11th Mar 2012 10:58pm
Easiest way would be to use one of those fuse adapters on the front fuse that supplies the feed for the accessory sockets and ten it could be run up the a pillar and tucked into the head lining Smile
This is what I plan for my blackvue, or hook into the power for the sunroof motor as its ignition fed Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #112549 11th Mar 2012 11:26pm
It's a long run. but you could tap into the live ignition feed in the left hand boot cubby (feeds the radio) then run it up through the C pillar and then the headlining. Or under the carpets and tread plates to the lower A pillar cover then up.
Is there no live ignition up in the interior lighting panel?
I prefer kingpleb's idea though. Off to have a look for fuse adapters? .
Post #112552 11th Mar 2012 11:48pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Which camera did you go of Stan ? Been thinking about this myself. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #112566 12th Mar 2012 7:16am
@mr pleb and joe, thought about the run from a live of a ciggy socket but i thought there might be a 'tap in' at the interior light cluster so as to save that hassle .. found this on the d3 site and this bloke uses a fuse adaptor thingy
http://www.disco3.co.uk/forum/topic70058.html
@jez, went for the cheapest unit i could find on ebay... goes onto a camera tripod screw on to a suction pad
Post #112575 12th Mar 2012 9:26am
You could always find an ignition controlled spare fuseway on the front fuseboard and plug into the live terminal with a male spade connector, then use an in-line fuse which could be located behind the cover of the fuseboard.
Cable from the fuseboard, up the A pillar behind the trim and then poked behind the front edge of the headlining.
Post #112576 12th Mar 2012 9:53am
Stan... If you have an "incident" does it stop recording automatically? Or in the heat of the moment, or battle!, if you forget to tell it to stop and save, will it just record over the "event"? Previously..
Post #112577 12th Mar 2012 9:54am
@nicedayforit, probably the best way to go as i dont think there's an ignition feed in the interior light cluster
@contraband, there is a setting for a 15 minute video recycle which i assume that once it gets to the end of 15 mins it will re-record from the beginning so there will always be a 15 min loop so to speak...i suppose at time of 'incident' i'll have to make an effort to stop the recording, at least i'll have 15 mins to think of doing that...
there are a few videos on youtube re this model which are interesting... ... - .- -.
Post #112581 12th Mar 2012 10:41am
