![]() | Home > Technical (L322) > Gearbox advice |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
Can't help you with where to go, but as Steve said above, when you go to get it fixed, ask around to see who will do the Sonnax valve body upgrade - well worth it. I had some stronger frictions put in mine as well - they are available from a local car over here - the Holden (GM) Commodore. The torque converter will be slowly disintergrating, which will probably stuff the pump up as well. If the pump housing is damaged, it will need machining, and as it is part of the trannie case, there are only a few people around that can do this properly - tolerances are VERY tight here, and if not done properly, this can lead to premature pump failure - mine was done wrong first time and lasted a week... All done properly now by someone else, and thankfully paid for by the first guy...
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Autolock in Crewe did mine and they always seem to have a range rover in ( which is a worry |
Ebajema, the problem with the GM5L40E installed behind the TD6 motor is that the valve body was cast using a slightly softer alloy. This seems to be a problem particular to this transmission and has nothing to do with the transmission fluid. The valve bores wear and the operating pressures become too low.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Thanks for that Andy, it's only 20 odd miles away, will give them a call. Mike No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
The vehicles at work have oil samples sent away for analysis, gives them a heads up for any problems brewing.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Mike
It's been a while since I started this thread, so here's my latest update.
Are you sure the filter was changed? If it was then it won't do any harm to change the sump oil and refill. Had the incorrect fluid been filled into your box I doubt it would still be going now, the seals are rather sensitive and as each oil type has different properties the incorrect fluid would soon cause lots of problems. If I were you I would keep driving it and see how it goes ![]() |
@ Steve MFr, don't you hate it that a manufacturer tries to save a few dollars on a pretty expensive piece of machinery (not just the gearbox but also the car) causing major money and a long term reputation issue. I can't believe that this won't have a negative impact on the use of GM gearboxes in new model cars.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
The trouble is that it's not as simple as the manufacturer tryingto save a few dollars (or pounds) on the manufacturing - it's really our fault as consumers. We want something that's perfect and will last forever, but we always want it as cheaply as possible.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Sad .......but true |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
i read quote like this evertime i read a thread on a gearbox going, not touching mine, its goes when it goes. 2004 black Vogue TD6 |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Well I didn't have the oil changed on my gearbox, and it's gone at 85k. I really don't think that changing old burnt oil which is full of crap, for fresh new oil, can 'cause' gearbox failure. If the gearbox is so far gone that it's only the crud and debris in the oil which is holding it together, I guess it might precipitate failure a bit quicker.
crud and debris sitting on the case broke down by the additives in new oil ? 2004 black Vogue TD6 |
