Home > Technical (L322) > Can't Turn Ignition Key - Any Ideas??
Page 1 of 3 123>
elbitrevnoc
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
As I type this the good lady wife is stuck somehwere in Hampshire with a flat battery in a 2006 VSE Td6, having left the lights on all day Rolling Eyes . However, whilst she has a friendly chap at hand, willing to sort a jump start, she says she can't physically turn the key in the ignition either!
I've not come across this before. is there anything that would mechanically prevent the ignition from turning if the battery were flat. I've asked her to try all the the things I can think of (including the obvious 'Is it in Park dear? - that didn't go down too well!), but I'm miles away.
Any ideas out there? She's calling breakdown service, but no guarantee they'll know either if it's something too left field.
Post #112865 13th Mar 2012 7:05pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
IIRC the transponder in the key links to the security system preventing a copied key (without transponder) from being used.
Post #112866 13th Mar 2012 7:13pm
elbitrevnoc
Thanks. I wondered about that, but surely that would be an electronic immobilisation and not a physical prevention from turning the key wouldn't it? Is there some form of electronic lock on the ignition switch that 'recognises' the right key?
Post #112869 13th Mar 2012 7:26pm
The key not turning is due to the battery being flat.
Once the battery is partially charged it will turn as normal.
Post #112870 13th Mar 2012 7:26pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
As above, that little weird noise you hear when you put the key in is the electronic motor locking the ignition and steering wheel.
Post #112871 13th Mar 2012 7:32pm
elbitrevnoc
Ah well, you live and learn! Thanks all for the info.
Post #112875 13th Mar 2012 7:43pm
daveo
be very careful jump starting your car, make sure the key is NOT in the ignition when you put the jump leads on and when you have put them wait a while for the voltage to become stable V8 facelift Range Rover Autobiography 22" wheels.
Post #112876 13th Mar 2012 7:47pm
Because the ignition is not on the coloumn as usual the steering lock is electric controlled by the chip in the key... Without power, the key will not turn off the immobilizer and steering lock which allows the key to turn the ignition...
Craig Thumbs Up
Post #112935 13th Mar 2012 10:26pm
elbitrevnoc
As always, top quality responses and advice! Bow down Thanks everyone.
The safety tip is appreciated as well Daveo, although, sadly, I have to say this is the third time I've had to jump start it. First time I've had the ignition lock problem though, but that's what happens when you leave the lights on a car that's already got a dodgy battery! Perfect explanation of the ignition lock Craig - makes sense to me now.
In all fairness the battery had already given enough warning that it was on its way out and a new one will be in place on Friday. That should be the end of the few gremlins it's caused.
Oh, and she got home by the way... Whistle
Post #112940 13th Mar 2012 10:41pm
The main thing is the wife got home safely my friend...
Craig Thumbs Up
Post #112942 13th Mar 2012 10:52pm
ebajema
Doesn't your car have the automatic headlight setting ?? I have it set on auto all the time and works fine almost always (every now and then the lights don't go off, but that is maybe because I accidentally touched follow me home i.e. pushed the indicator stalk forward). MY 2010 5.0 SC Galway green and sand interior!!
Post #112971 14th Mar 2012 9:55am
elbitrevnoc
Yep. It's on auto setting 99.99% of the time, but I think she had overriden it as it was bright, but foggy.
I think it's a bit of a design flaw actually as you have to do the same if you want to use the fog lights - you just have to ro remember to switch back to 'auto' when you're done!
Post #112984 14th Mar 2012 10:36am
Ahhh, maybe she should be forgiven then if it was foggy... Bloody pain the fog light thing with auto lights...
Craig Thumbs Up
Post #112986 14th Mar 2012 10:42am
ebajema
Hi Craig, I agree a bloody pain in the behind, I have looked in the settings and you can't turn it off (at least I have not found it). MY 2010 5.0 SC Galway green and sand interior!!
Post #112988 14th Mar 2012 10:49am
Maybe possible with "Autologic!"? Im guessing...
Craig Thumbs Up
Post #112994 14th Mar 2012 11:05am
Page 1 of 3 123>
